RV.Net Open Roads Forum: General RVing Issues: Extension cord shrinkage
 > Extension cord shrinkage
Grumpa
Albany,OR
Posted: 09/10/21 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone else have this issue with molded plug ends on power cords? The cord jacket shrinks and pulls out end. I would post a photo,lost at getting it done
IAMICHABOD
Sunny So Cal
Posted: 09/10/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
I had this happen on my shore line power cord after 15 years of use.
I just replaced it with the best one on the market today with a Progressive Industries male plug.
Former El Monte RV Rental
Buying A Rental Class C
pianotuna
Regina, SK, Canada
Posted: 09/10/21 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I've had it happen.
I simply wound some electrical tape until I could replace the end.
Regards, Don
time2roll
Posted: 09/10/21 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
Lay the cord out in the warm sun a few hours. Then start at the RV and pull the cover toward the plug along the length of the wire. I put some JB Weld in the moulded end as I pulled the cover toward the plug and it has now held for many years. No issues again.
675w Solar pictures back up
Posted: 09/11/21 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Short answer.. YES.
The cord jacket shrinks... only soultions I know of are replacement the ends (Shortening the wires) or perhps heat shrink tubing (First remove the plug then slip heat shrink over the end and jacket) Finding heat shrink that large I never did, use 2 or 3 layers. Replace plug with new end (Well the first time just a replacemnt plug and ciut the wires back_)
QCMan
Independent Republic of Horry
Posted: 09/11/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
This is the best bet! I would suggest unhooking the cable from the trailer if it can be done as it will also let you make the best of the job by holding the wires as you pull the jacket thus giving you more jacket to pull instead of putting tension on the connections. If done this way JB may not even be needed but could be used for insurance. When you are done, put a cable clamp around where the jacket ends on the trailer end to keep it from migrating. Happy Camping!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Posted: 09/11/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I’d tape the schitt out of it and carry on.
Electrical tape or rubber tape or liquid electrical tape.
Use it til it doesn’t work.
2017 Heartland Torque T29
dodge guy
Bartlett IL
Posted: 09/11/21 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Replace the end with one where it clamps the jacket so it can’t pull out.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Grumpa
Albany,OR
Posted: 09/11/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all. Replace is the go to.
