RV.Net Open Roads Forum: Towing: who's towing with gas and 342 vs 373
Search only in Towing
Open Roads Forum  >  Towing
 > who's towing with gas and 342 vs 373
jffnkrn
peoria
Posted: 09/11/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Just putting the feelers out; who's towing 14k with GM gas, 6.6 and with 373 or 342. How do you like it, How don't you like it. ???
theoldwizard1
SE MI
Posted: 09/11/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
What transmission ?
Can you manually drop it down 1 or 2 gears for hills ?
Posted: 09/11/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
First, you can’t get 3.42s in a HD gasser and I believe I read 3.73 is now the only final drive option for the gassers. Which is really about the same as a 6.0 4.10 setup from the previous model. Not a huge leap in power anyway.
Towing 14k high profile trailer will be ok at low altitude and decent in the flatlands. Will struggle with big grades, you won’t maintain freeway speeds and will be really underpowered for high altitude + grades.
A lot of money to spend on a truck that won’t pull as well as a 15 year old Duramax.
2017 Heartland Torque T29
Posted: 09/11/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
What transmission ?
It won’t pull 14k high profile trailer in 6th gear on flat roads unless there’s a tailwind.
Of course you can drop gears. Hasn’t been an auto trans that can’t since the inception of them that I’m aware of.
jffnkrn
peoria
Posted: 09/11/21 10:07am Link  |  Quote  |  Print  |  Notify Moderator
yeah 6 speed tranny with manual for hill climbing and descending. In the other trucks, I would run in 5th to keep it from trying to go into overdrive/6
blt2ski
Kirkland, Wa
Posted: 09/11/21 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Not a 6.0/6.6 V8...
But pulling 8000 with a 6sp/4.3 V6, I had no issues pulling 55 mph on a 3-4% grade in 4th. Ie basically direct at 1.05. 3500rpm or there about. I have a 285/300 motor.
I don't think the naysayers realize that a 350-400hp gas motor will pull most trailers fine.
Elevation as noted, above 5-6000', you will notice the typical 3% HP drop per 1000'. Unlike a turbo/super charged motor you will not not HP loss until 8-10,000 feet. If in the Rockies ALOT, get a forced induction motor. A once in a lifetime trip, a gas will get you from point A to B safe and sanely. Just slower.
Marty
2014 Chevy 1500 Dual cab 4x4
MitchF150
Puyallup, WA
Posted: 09/11/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Mostly depends on how you feel about running rpms when needed.. Let the thing rev when you need the power. Trans will downshift on it's own, but locking out top gears is good for the flats, as lugging or bogging any engine is not good either..
I've got an 3.5 Ecoboost, 6 speed and 3.73 rear gears towing a #7000 TT.
It likes the flats in 5th and the grades in 4th. Never need to 'mat' the pedal unless passing and need that extra power 'right now' and it responds wonderfully. [emoticon]
With a big V8, they still like the rpms, so just don't be afraid to use it. You'll figure out over time what works best for your combo. Actually, you should find that running around 500-600 more rpms on the flats will net you better mpg's then bogging it when loaded..
Good luck! Mitch
Posted: 09/11/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
Not a 6.0/6.6 V8...
Marty
Apples and tomatoes though. Take your 4ton flatbed and turn it into an 8x12x30’ long box and take the same hill with a little headwind and report back.
Those 4.3s are stout little motors, but I presumed the OP would have a high profile trailer if he’s talking 14klbs and his location and intended use is typically wonderfully unspecific, like a lot of queries here.
And since there’s at least a half dozen states with towns named Peoria (or peoria as entered in his profile), a 200mi radius around Peoria IL or IN is wholly different than the same around Peoria AZ or CO.
Great to be marginally equipped if it’s all one can afford or chooses to spend, but OP is talking about new trucks and $60k for a rig that performs marginally, doesn’t make a lot of sense to me. Nor may it to the OP who obviously doesn’t have the experience, if asking the question.
KD4UPL
Swoope, VA
Posted: 09/11/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think you can get anything but the 3.73.
I too am curious how these gas engines do towing heavy. My 2005 Duramax is at 292,000 miles and I'm thinking of replacing it in a year or so. I don't usually tow more than about 14,000 with the truck loaded to about 10,000 with my tools. I'm undecided if I really want one of these new, complicated, temperamental, expensive diesels. I can't find much real world info on people using the gas trucks for work and towing on a regular basis.
BarneyS
S.E. Lower Michigan
Posted: 09/12/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
I have had two diesel trucks. I didn't find either one to be complicated or temperamental. One was a 2002 F250 with the 7.3 PSD and the other, and my favorite, is the 2016 Ram Cummins TD pictured in my signature. Both trucks ran flawlessly for thousands of trouble free miles and gave excellent towing performance.
The cost of an oil change was higher ($55-$90) because of the amount of oil in the crankcase (16 quarts if I recall correctly). Other then that, the diesels didn't cost anymore to maintain than my previous gas engines. Of course they do cost more up front though but that is a slight disadvantage, in my opinion, compared to the improved towing performance that they give.
Barney
Not towing now.
