RV.Net Open Roads Forum: Fifth-Wheels: Anyone use a solar TPMS?
 > Anyone use a solar TPMS?
way2roll
Wilmington NC
Posted: 09/11/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
In the past we had TST 507 that I let go with our last MH. I am shopping for a new set for the FW. I must admit I was never completely happy with the TST's. I know most people like them but I constantly had 1 or 2 sensors that would lose a signal. TST was great about support and actually replaced 2 of them admitting they were faulty, however it happened again with the replacements. Anyway, shopping for new ones and I see TST prices are about 2x what they were a few years ago. I saw a few on Amazon, and some solar ones with excellent reviews. Much cheaper as well, although I do find you often get what you pay for. I only need 4 BTW. The sensors use batteries but the main unit is a solar mounted dash setup.
Thoughts?
solar TPMS
way2roll
Wilmington NC
Posted: 09/11/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
On second thought, these may not work. I just saw max psi reading is 87. My FW tires are supposed to be 80 cold and I am sure they'll heat up to 87 at some point under normal conditions. That's too low a threshold to indicate a real problem.
But, I will take recommendations what TPMS you guys are using for your FW's.
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 09/11/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
I bought the solar ones for about $18 and they work but I would be using them on my 5th wheel. I use them on my car trailer and other utility trailers but the TST has saved me from trailer damage and spotted a slow wheel leak. BUT as you say I have lost them on and off. I have to change out the batteries every time I plan a trip.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
spoon059
Just north of D.C.
Posted: 09/11/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
FYI, that one isn't recommended for trailers. They have a link to a "newer" one that is recommended for trailers. Still 87 PSI but its $160. I'm not sure that being limited to 87 PSI is a bad thing, I'm much more concerned with a dropping tire pressure and would set a minimum threshold, not a maximum threshold. Looking at the questions, it says it has a max pressure of 99 lbs.
It also monitors temperature somehow (not sure how that works on a valve stem).
Anyway, deal of the day for $63 I bought one and I'll see how it does. The 87 PSI doesn't worry me. The 36' range could potentially be an issue, but it looks like they have a range extender. If it doesn't work, I'll return it. That's a good deal though!
* This post was edited 09/11/21 02:10pm by spoon059 *
2015 Ram CTD
2015 Jayco 29QBS
wanderingaimlessly
Buggs Island lake
Posted: 09/11/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I bought this one tpms and so far it seems to be working correctly. Only had it for four months, but ok so far.
And this one goes to 130 psi.
guidry
Texas Cajun
Posted: 09/11/21 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought this one and can't get it to keep with three of the four 5th wheel trailer tires. Really disappointed because it got good reviews and a good review on youtube. If you get one you may try to get one that includes a booster.
TPMS from Amazon
Lynnmor
Red Lion
Posted: 09/11/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Can you put the truck in the garage, or do you need it to sit out in the sun?
Ivylog
Blairsville, GA and WPB, FL.
Posted: 09/12/21 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Just bought that unit on Ebay for $19.50 but using it on my truck… not sure how far it will transmit but for my price, why not? It has a power plug IF the battery needed extra charging.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
way2roll
Wilmington NC
Posted: 09/12/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the suggestions. Good point on the max psi. I'll check out the other ones you guys suggested.
