RV.Net Open Roads Forum: Class C Motorhomes: Onan 4000 Genset K-1 Relay-Starter Connections
 > Onan 4000 Genset K-1 Relay-Starter Connections
kioticoachman
17821
Posted: 09/11/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
In the process of replacing the generator filter & pump on an older RV. The Generator is a model 4KY-FA26100J. In the process this SC lost the correct cable connections for the Relay. There are 5 wires/cable that were connected. 2 cables & The K1-Bat - K1-S - K1-1 that I'm not sure where these K-1 go? Can somebody help?
Will try to post/attach a photo? Hope this may help? Any assistance or suggestions would be appreciated. Thank you very much! KK USAF 62-66
Click image for larger version Name: 156.JPG Views: 3 Size: 1.04 MB ID: 342660
bobndot
Posted: 09/11/21 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Will the manual for the genny help ? If not google “your model number wiring diagram”
It will show the wiring pdf for your genny.
https://www.cummins.com/sites/default/files/rv-manuals/0981-0621.pdf
See p 38
kioticoachman
17821
Posted: 09/11/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
See p 38
Thanks for taking the time & sharing the link. I'll see what I can do? Also need some help on how to post photo? Thanks again! KK
bobndot
Posted: 09/12/21 12:34am Link  |  Quote  |  Print  |  Notify Moderator
In the past i always used Photobucket aa a host , using the yellow box to copy the pic using the “Reply to Topic not Quick Reply. “. You could preview your pic using the 3rd icon which is a magnifying glass symbol.
But most of the time now, I’m using my Iphone and i have no idea how to post pics using my phone. Here is something from the Tech section.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/15775751.cfm
* This post was edited 09/12/21 12:41am by bobndot *
