RV.Net Open Roads Forum: Class A Motorhomes: Class As in cold weather?
 > Class As in cold weather?
rgatijnet1
Posted: 09/12/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
We use our gasser almost exclusively in the Winter out West. We spent many nights below zero in the mountains. We always took chains because you never knew when a snow storm would pop up. We also hooked up to shore water only to keep our water tank topped off. We only hooked up to the sewer to dump our tanks. In the wet basement compartment we put in a thermostatically controlled 150 watt incandescent light bulb installed in a trouble light wire cage. We disconnected and removed the ice maker hose. We never had the RV water pump or a water line freeze. Inside we used our furnace very seldom since a couple of 5000 watt space heaters were sufficient in all but the coolest temps. We also carried a portable heat pump that we vented to the outside, which was quiet and worked well to keep things comfortable in below zero temps. A portable 120 volt heat pump is never exposed to the outside temps so they will work at below zero temps. We also used small fans to blow on the windshield to keep it from frosting up. The other windows were double pane which helped keep the interior warm. I believe with proper preparation and with some limitations most any RV is usable during the Winter months.
Bruce Brown
Northern NY
Posted: 09/12/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
LouLawrence wrote:
Class A diesel units are going to have some version of Aquahot diesel fired baseboard heat. This also heats the wet bays and keeps everything nice and toasty. If the unit you look at does not have this then pass.
Terrible advice - lots of nice units without Aquahot.
To the OP, better advice is to check the R value of the MH you are considering. Some simply have better insulation properties than others. Our original Winne and next Fleetwood wouldn't do well in winter, and we sweat in the summer. When we started ordering we went for dual pane windows and a better built unit. Heat or cold, we're good now.
We have camped as low as 15F with our NON-Aquahot DP with no issues whatsoever.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
dalenoel
S.E. Michigan
Posted: 09/13/21 05:43am Link  |  Quote  |  Print  |  Notify Moderator
We use our non-Aquahot DP all the time and do not have problems without strip heaters in the AC units and only have one furnace. But we are only 36' long.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
Sandia Man
Rio Rancho, NM
Posted: 09/13/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Too many variables involved to simply say class A rigs across the board are better for cold camping than 5ers, TTs, or class B/C rigs. One thing for sure is any RV can be easily modified for cold weather use, we have done this to every RV we have owned over the last 3 decades including our current class A Monaco. We do lots of sub-freezing camping but not for weeks on end, usually a few days is plenty as we do like enjoying the outdoors without freezing our tails off. Truth be known, RVs are just not designed to withstand long term below zero extreme cold usage from the factory.
As we got older and now camping without our kids we went from having 5ers, TTs, and toyhaulers to a class A rig, it is easier overall which keeps my DW happy, she was losing interest in RVing and now is invigorated to set out for our next excursion. We took our time researching the many aspects of motorized RVs, drove as many as we could to help decide which chassis and drivetrain we felt suited us best. Doing your homework is critical for motorized RVs, getting it wrong could cost 10s of thousands of dollars of repairs down the road and severe loss of value when reselling.
mountainkowboy
Socal/NE Oregon
Posted: 09/13/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
We're good down to 24F without issues. Lower than that needs much more attention to keep from freezing. Pull the slides in, go on tank water, and have a few lights in the service bays. Go find a warmer place to park, they really weren't designed for use in sub zero temps.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
LouLawrence
Traveling the US!
Posted: 09/13/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
We often spend months in below freezing night time temps (still working for a living). We can't imagine trying to do that with propane unless you have lots of free time in your week to refill those tanks on a fairly regular basis. For any long term cold weather camping you are going to need electricity to keep everything warm and your costs to a minimum.
wallynm
Los Alamos NM
Posted: 09/13/21 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Not all diesel Class A have an aqua hot system! If that is what you want check it out before buying!
LouLawrence wrote:
Class A diesel units are going to have some version of Aquahot diesel fired baseboard heat. This also heats the wet bays and keeps everything nice and toasty. If the unit you look at does not have this then pass. All the plumbing in inside the coach so even if it got really, really cold you could add a small electric heater or a light bulb or 2 to the wet bays and you will be fine. We have traveled in most every weather you can imagine and we have been fine. I must say that when the company sent us to ND in January (20 below zero) we passed and drove our car and stayed in a hotel!
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
