RV.Net Open Roads Forum: Towing: Broke my hitch pin today
Search only in Towing
Open Roads Forum  >  Towing
 > Broke my hitch pin today
Page of 5
time2roll
Posted: 09/11/21 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.bulletproofhitches.com/colle........ches/products/3-0-heavy-duty-6-drop-rise
Just a random search. Not exactly common or low cost.
675w Solar pictures back up
JRscooby
Indepmo
Posted: 09/12/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Not sure, but I would think anybody that could modify the hole in receiver could build up the outside of the shank. And for hamn sure, it would be cheaper to go back if you or next owner decided to tow a trailer that needs the bigger hitch. Just buy the shank.
noteven
Turtle Island
Posted: 09/12/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
You could have a welding / fab shop make a shank to fit your wd hitch. Steel, holes, welding done by a pro.
Posted: 09/12/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Whangler wrote:
Lynnmor wrote:
Since the 3" to 2" adapter places the load points 1/2" apart, that is asking for trouble. Also, 3" receivers require a 3/4" pin, but you probably used a 5/8" because that is what fits 2" shanks. Reese has sent much production to China and it would be a good idea to avoid those products.
I've never liked that 3"-2" adapter set up. Think I'll visit the welder when I get home for some mods to the receiver.
There is maybe some misinformation in your posts.
First, glad you had everything hooked up right and kept the trailer rubber side down! Probably need a new drivers seat cushion after that. I would!
1. Unless it’s an aftermarket hitch, your truck has a 2.5” hitch.
2. The pin got fatigued from being bent due to the adapter sleeve. Common issue with the use of adapter sleeves. Never broke one, but I’ve cutout several bent ones out of our job trucks. Those things are dangerous and they’ll destroy the pin holes in your receiver.
3. I looked on etrailer and believe your correct. No 3” wdh shanks. Likely because anything with a 3” hitch (exclusive to Ford OEM afaik) shouldn’t need a wdh. I’m not even sure there are aftermarket 3” hitches. I believe it’s just a Ford gimmick. Although I believe the bolt spacing on a lot of drop hitch shanks is “universal”, so you should be able to replace the shank with a 3”, if needed.
4. It’s possible it was a defective pin, but highly unlikely and your failure is an expected symptom of using an adapter sleeve which allows a bending moment to be put on the pin, rather than just shear, as designed.
If you really do have a 3” hitch, don’t go farking it up at the corner welding shop. The hitch and truck will hold your camper and if it’s tongue heavy enough to need weight dist for the springs, beef them up and haul the trailer without a wdh. It’s likely a placebo anyway.
If none of that works, get a 2.5” receiver if you just gotta have a wdh. They’re not that expensive. But please confirm you have a 3” hitch first.
Side note, most “RVers” will chit all over my last recommendation as they feel they need a wdh with sway control without exception, kinda like a baby and it’s blanky and binky.
But if you don’t believe me or the rest of the world that hardly ever uses them, watch every TT you see being hauled by a transporter. 99.5” chance he has no wdh on it. And he probably tows 50 of them a year!
* This post was edited 09/12/21 12:40pm by Grit dog *
2017 Heartland Torque T29
Posted: 09/12/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Although if you welded the adapter in solid around the face of it, it would work and keep from bending the pin. But you should be a better engineer and metallurgist than I to trust that you didn’t make the end of the receiver brittle or somehow weaker by welding on it.
(I believe it would work but I wouldn’t trust my truck, trailer and life unless I designed it, which I’m now incapable of doing. Too long since college!)
Also is your receiver pin holes wallered out now? That’s what usually happens along with bending the pin.
Posted: 09/12/21 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Good point. No one sells 3” wdh, I think, but the bolt spacing on drop hitches may be common to reg and wdh, in which case there are plenty of 3” adjustable drop shanks available.
Still doubt OP has a 3” hitch though unless the hitch was modified.
deltabravo
Spokane, WA
Posted: 09/12/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Replace the hitch shank with a 3" version.
"Modifying" a trailer hitch by welding on it is never a good idea.
Tom/Barb
Oak Harbor, Wa
Posted: 09/12/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
This is why I reamed to the next larger hole and use a grade 8 bolt and self locking nut..
noteven
Turtle Island
Posted: 09/12/21 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi deltabravo - why do you question welding a hitch shank using proper workmanship?
Lynnmor
Red Lion
Posted: 09/12/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
The problem is that there may not be any 3" shanks that work with weight distribution made. If a source is found, please post it.
Page of 5
