RV.Net Open Roads Forum: Towing: Broke my hitch pin today
Search only in Towing
Open Roads Forum  >  Towing
 > Broke my hitch pin today
Page of 5
mkirsch
Rochester, NY
Posted: 09/13/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
deltabravo wrote:
Whangler wrote:
I've never liked that 3"-2" adapter set up. Think I'll visit the welder when I get home for some mods to the receiver.
Replace the hitch shank with a 3" version.
"Modifying" a trailer hitch by welding on it is never a good idea.
Hi deltabravo - why do you question welding a hitch shank using proper workmanship?
How, exactly, do you ensure "proper workmanship?"
I'm not an expert in welding. Most people aren't.
I do not know what goes into the design of a hitch shank. Most people don't.
I don't know anyone who could tell me with certainty that something as critical as a hitch shank is constructed with "proper workmanship." Most people don't either.
How do I know that someone didn't just lay a pretty "stack of dimes" but got ZERO penetration in the weld? How do I know that the builder didn't put too much heat into the weld making it brittle? Short answer is I don't, until the trailer decides to part company with the truck. Then it's too late. Will the fabricator stand behind his work, or when you point at him and say, "His fault," will he claim to have never seen you before in his life?
At least something commercially made has a big nameless faceless corporation and a fat liability policy for the other guy's lawyers to go after.
Whangler
Northern CA
Posted: 09/13/21 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
OK fellas,OP here, mea culpa. Its a 2.5" hitch receiver and I'm using a genuine GM reducer to 2". There's a bit of play between the reducer and the hitch receiver and lots of play between the 2" shank and receiving end of the adapter.
I should have known that all these HD trucks would have a standard equipment hitch receiver that fits available WD shanks. Now I see there are readily available 2.5" WD shanks that fit my equalizer system. Thats what I shall get after this trip.
Thanks for your help!
time2roll
Posted: 09/13/21 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect [emoticon]
675w Solar pictures back up
Posted: 09/13/21 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
I has another question for the OP - why is there a "3 inch" receiver on a pickup truck?
Or does it have 3x3x .250 tubing reciever which = 2-1/2" inside which would be the 2-1/2" receiver hitch like my Ford F350?
Alot of newer Super Dutys have 3" receivers now as well.
2017 Heartland Torque T29
Retired JSO
North Georgia Mountains
Posted: 09/13/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just weld the adapter to the stinger and be done with it. You can buy extra adapters and a cheap hitch shank if needed for say a utility trailer etc.
Lynnmor
Red Lion
Posted: 09/13/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
That's the right way to do it. Just so you know, there are many made with the 3" receivers and there is little that will fit.
There have been reports of pins being bent when using the adapters going from 2-1/2" to 2".
noteven
Turtle Island
Posted: 09/13/21 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
If you do not know good welding workmanship from not good, why do you talk about stacks of dimes, heat control etc
How does a mild steel welded piece fail, generally?
Trust me - a trailer hitch shank is not a huge challenge for a professional welder anywhere there is a certification program for the trade.
noteven
Turtle Island
Posted: 09/13/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Ya had us going there fixing that 3" problem for ya! hahahaha
Anyways there is a whole herd of 2-1/2" receiver WD shanks available to choose from. You are away to the races.
deltabravo
Spokane, WA
Posted: 09/13/21 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
It will still have a lot of slop and play in it.
Timmo!
FYJB! Yep, FYJB!
Posted: 09/14/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Maybe I missed it, but did the OP ever locate the "broken hitch pin"?
Could the issue be "operator error"? And not "equipment failure"?
Page of 5
