RV.Net Open Roads Forum: Tech Issues: Dirty Electric
 > Dirty Electric
path1
Varies with weather
Posted: 09/11/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
How would I know or test if a generator was putting out the wrong frequency or "dirty" electricity?
(recently changed oil, new plug, new air filter, cleaned out carburetor best I could... wondering if there's anything else I could do to see if this thing running right. Eu2000iHonda...unknown model year.
enblethen
Moses Lake, WA
Posted: 09/11/21 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Many gensets the frequency and voltage is set by engine RPM. a meter such as this that has a frequency range.Meter
Normally with no load frequency will be around 62. It should fall to 60 Hz when under some load.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Matt_Colie
Southeast Michigan
Posted: 09/11/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Path,
That is supposed to be an inverter generator. That means that it uses a computer to artificially create the power wave shape. If it is working at all, it is probably in spec, but it is probably not "clean" power. The instruments to tell if it is clean are both rare and expensive.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
time2roll
Posted: 09/11/21 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
EU2000 is clean or no power.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 09/11/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Inverter gens are about as clean as it gets. Often better than shore power.
Regards, Don
path1
Varies with weather
Posted: 09/11/21 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you everybody. Electricity is a mystery to me, the last couple Harbor Freight volt meters (linked to in reply) I got, bit the dust, so I dug deep in my back pocket and got a fluke 117, turns out to be a mistake on my part. I have to look in it's manual every time I use it becauce it's does so much. But has a Hz button but only goes to 50. So much for expensive meters. Then Remembered my "kill a watt" measuring device thing with a hz button.
Then after reading replies I'm okay... it either works or it don't work.
path1
Varies with weather
Posted: 09/11/21 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
P.s. kill a watt measured 59.9
Gdetrailer
PA
Posted: 09/11/21 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Path,
Matt
$50 says you are wrong.
Thats a handheld Oscilloscope which can be bought for under $50 HERE
Good enough bandwidth to see distortion, misformed waveforms and spikes along with gives you frequency and peak to peak voltage of the 60Hz waveform all in one package.
2112
Posted: 09/12/21 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Close. This scope has 50V pk input. You would either need a 10X probe or a step down transformer such as THIS to protect the input. That will cost you another $10. I use the transformer for isolation as well. I just wanted readers to be aware another component would be required.
120V RMS is about 170V pk so you would expect to measure 17V pk using this transformer. 60Hz would be 16.66 mS pk to pk.
* This post was edited 09/12/21 06:59am by 2112 *
2013 KZ Durango 2857
Matt_Colie
Southeast Michigan
Posted: 09/12/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
GD,
While that is a cheap version of an Oscilloscope, even with the suggested additional parts to look at the wave shape, you can't use it to do either a true THD (Total Harmonic Distortion) measurement. All you can do is look at it an see if it is pretty.
This came up recently when an acquaintance could not run his new inverter microwave from the CCV portable generator. We got things together and found that his machine produced a really big 3rd and fifth order that fooled the power supply of the microwave.
The microwave ran fine with the power from my 48yo Onan even with the distortion cause be cylinders firing.
Matt
 > Dirty Electric
