RV.Net Open Roads Forum: DC current draw at rest, 2.3 amps with nothing on
 > DC current draw at rest, 2.3 amps with nothing on
patricklcam
Salt Lake City
Posted: 09/12/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have a new to me travel trailer with the discontinued American CS 6000 power distribution unit.
With no shore power attached and all DC fuses removed I see a 2.3 amp draw from the battery.
If I detach the battery charger at the distribution panel + terminal the amperage draw goes down to .25 amps.
Measurement is made by putting amp meter inline between the + battery post and the + input wire.
Is this a normal parasitic draw for the CS 6000 unit?
I know the battery charger in the unit is not that good, cooks battery and is not lithium compatible. Just trying to figure out what is normal before changing things out.
Thanks in advance
Pat
DrewE
Vermont
Posted: 09/12/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
That is not a normal parasitic draw for any converter. It should be a few orders of magnitude lower.
time2roll
Posted: 09/12/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
A 2 amp draw is exceedingly high for any modern converter. Maybe a few milliamps but 2 amps is huge.
My trailer idles at 500 milliamps (1/2 amp) with the fridge running and everything else off but not disconnected.
675w Solar pictures back up
dougrainer
Carrolton, Texas
Posted: 09/12/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure your Trailer Brake a way switch is also disconnected. There may be a slight fault in it drawing power. The Brake a way is wired direct to the battery POS post. Also, check your LP sensor. It may also be wired direct and not be fused at the Fuse center and have its own fuse. Doug
patricklcam
Salt Lake City
Posted: 09/12/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all.
I took the charging unit out and put on a bench to make testing easier.
Found a questionable solder joint which I re-soldered.
Applied battery power to the +- terminals, still 2.3 amps.
No components burnt or any other visual indications.
Current battery is a single marine deep discharge, powering lights, roof fan and a heater fan.
Someday trailer will have a lithium in its place, maybe 2.
Checking prices it looks like replacing the entire distribution panel with charger is just a few dollars more than the charger alone.
I guess I will change the whole thing out for a Progressive Dynamics Mighty Mini 60 Amp PD4060K unless there is a better option you might recommend.
philh
Belleville MI
Posted: 09/12/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure your replacement has high enough voltage for lithium
StirCrazy
Kamloops, BC, Canada
Posted: 09/13/21 07:42am Link  |  Quote  |  Print  |  Notify Moderator
patricklcam wrote:
Thanks all.
I like PD, and if that is discontinued it is a good upgrade. thats weird to have a high draw like that, how old is it?
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
BFL13
Victoria, BC
Posted: 09/13/21 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
deleted
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Huntindog
Phoenix AZ
Posted: 09/13/21 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
My Momentum idles at about 1.65 amps.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
1380 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
