RV.Net Open Roads Forum: Tech Issues: Inverter cooling fan
 > Inverter cooling fan
S Davis
Western WA
Posted: 09/12/21 11:52am Link  |  Quote  |  Print  |  Notify Moderator
I am getting ready to install a Outback VFXR2812 inverter, it is going in an enclosure and needs ventilation. Those of you with an enclosed inverter what are you using for a cooling fan? The inverter can support up to a .7 amp draw for the fan.
pianotuna
Regina, SK, Canada
Posted: 09/12/21 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
S Davis
What is the wattage of the inverter? What is the efficiency?
For example 1000 watts at 9% = 111 watts of heat to dissipate.
From that you could calculate the air flow needed.
I would use DC computer fans, one to exhaust and one to blow into the box.
I'd use a mechanical thermostat to control the on/off cycling.
My Magnum caught on fire--because it uses AC controls (or perhaps AC fans).
Regards, Don
2oldman
NM
Posted: 09/12/21 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
S Davis wrote:
I am getting ready to install a Outback VFXR2812 inverter, .
Excellent choice! The Outback units are built like tanks and should last forever. Note that it weighs 60lb, so there's probably enough heat sink in that mass you may not need to ventilate it. I doubt the mfr just forgot about cooling an inverter that expensive.
I have the 3648A, and I never hear its fan, nor do I know if it even has one. It's in the basement, not a small enclosed space however.
* This post was edited 09/13/21 08:15am by 2oldman *
Itinerant1
Itinerant
Posted: 09/12/21 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
As Pianotuna points out if your inverter uses the ac to run its fans let it cooldown before turning it off.
I run my Magnum for hours powering the ac unit but I make sure that the front compartment is open for air circulation under those conditions. Also the inverter is on 24/7/365.
12v 500ah (5,120Wh usable), 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 1,800+ cycles.
gatorcq
Arizona
Posted: 09/12/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased 2, 4" muffin Fans. Run in series. 1 intake, 1 exhaust.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
theoldwizard1
SE MI
Posted: 09/13/21 02:51am Link  |  Quote  |  Print  |  Notify Moderator
The best/quietest computer fan (12v) are made by Noctua.
S Davis
Western WA
Posted: 09/13/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input I am going to go with two Noctua NF-A14 iPPC-2000s to start and will monitor temps and add more if needed, I have a four fan control with individual temperature settings so I can stage them based on the temperature in the enclosure.
