Y-Guy
Tri-Cities, WA
Have you had any communications with Roadmaster about the failure and the connection point?
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
willald
NC
dodge guy wrote: A Jeep Wrangler or a base model 1/2 ton 4X4 will be under 5k lbs.
Right, but as I said in my post, 'unless you want a small SUV or pickup...'.
Everything you mention here is just that, either a SUV or pickup.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
j wackerly
29575
Y-Guy wrote: Have you had any communications with Roadmaster about the failure and the connection point? I did send my photo to roadmaster . I have not heard back yet ?
j wackerly
29575
The consumer is stuck in the middle if you tow a unibody car . Did Ford or Roadmaster do there home work on the stress on a unibody car ? They are going to point there fingers at the consumer because nobody but you installed it . The car I replace it with a Buick SUV . The dealer probably thot I was crazy because i got under under the car in the show room looking at the way the unibody was made . The unibody was all one piece and the Roadmaster base plate had 8 bolts on each side not 3 like the Ford . I hope i made the right choice . It is a shame the consumer has to a structure engineer in this case .
Y-Guy
Tri-Cities, WA
j wackerly wrote: Y-Guy wrote: Have you had any communications with Roadmaster about the failure and the connection point? I did send my photo to roadmaster . I have not heard back yet ?
Thanks, that is sort of what I would expect. Sadly, in this day and age of lawsuits many will not respond. While I personally think each part car & baseplate worked fine on its own they did not work together as the consumer would expect. I wish you the best with your new toad! Thanks for sharing the problem you ran into, though I wish it hadn't happened in the first place.
hohenwald48
Nashville, TN
j wackerly wrote: I have done some research on base plates and nobody makes a base plate that extends past where my failed at . If you look at the photo on page 4 . This is where the base plate should extend to .
I agree, it looks like none of the baseplate manufacturers have done a good design job for the Focus. A lot of them make sub par baseplates for the Wrangler too. The fix for this design flaw is almost always a short little cable to attach to another location in case the primary attachment point comes apart. Even that kind of indicates the baseplate manufacturer knows there's a problem.
Unfortunately, it's up to the consumer to figure it out. Shouldn't be that way but it is. I suppose the Focus used by the baseplate manufacturer for the initial design could have been manufactured differently than subsequent years. The baseplate guys should be sure of that before telling a customer "yeah, it'll work."
I put it in the same category as the RV sales person who says "sure your F-150 can pull a 40' bumper pull toy hauler with no WDH". But it happens.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
