RV.Net Open Roads Forum: Towing: 2-1/2” Hitch extension?
Search only in Towing
Open Roads Forum  >  Towing
 > 2-1/2” Hitch extension?
Blazing Zippers
North Idaho
Posted: 09/19/21 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
With regard to decreased capacity of an extended shank---I've had two of them on two different trucks. No problem at all. On my current set up, the Equilizer hitch actually takes up a fair amount of the weight transferred to the truck.
Anyway, they have worked well for me, and I can lower the tailgate without denting it on the hitch. It also allows tighter turns too.
Posted: 09/20/21 12:48am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the length of the hitch extension (obviously) and the load.
I fully understand that and the math behind it.
Fact is, my hitch is super short and a short extension will put it similar to a normal hitch. No large cantilever for the tongue weight I have.
2017 Heartland Torque T29
Posted: 09/24/21 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Anyone know of a source for short 2.5” extension?
I even hit up the Fleet Farm last weekend when I was in Minnesoooota, no dice. 100 different hitch parts but not what I need.
* This post was edited 09/24/21 04:17pm by an administrator/moderator *
Posted: 09/24/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Ha, just called Torklift here. He said 24" ext is the shortest he's ever seen, so I believe that could be considered final answer!
I need another project like a hole in my head, but gonna have to make one I suppose.
Posted: 09/30/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
So, quick measurements on my receiver and stinger, and it would seem to be no issue to make an extension about 8” long. 6” wouldn’t quite work. And obviously anything longer would work fine.
Seems strange with the vast number of 2.5 and 3” hitch trucks that this product is not available. Of the 2 trailers I own and 1other that I tow sometimes with my personal truck, all would be mush more user friendly if separated from the ass and of the truck by a bit more.
Oh well, put it on the to do list I suppose. Haven’t researched tubing yet to see if I can build one with heavy enough tubing for the plug end of the extension so as not to need to get solid bar stock.
ford truck guy
Pennsylvania
Posted: 09/30/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
My mistake......
I just checked mine and it IS a 2"receiver extension.... NOT 2-1/2"
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Lynnmor
Red Lion
Posted: 09/30/21 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I guess that the Reese shank, that I linked to, wouldn't give you the length required?
BenK
SF BayArea
Posted: 09/30/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
If me, just buy the shortest and cut it down to whatever length you need/want...drill new holes as needed
then paint it with zinc rich paint
-Ben Picture of my rig
Posted: 09/30/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Yessir I believe it would, thanks.
Maybe I didn’t explain, but I have a nice shiny new adjustable aluminum drop hitch that I’d prefer to use.
Posted: 09/30/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
That’s a good idea, but would still have to weld a reinforcing collar around the receiver end of the extension after cutting it down.
