RV.Net Open Roads Forum: Fifth-Wheels: Hangers/Springs/Axles
 > Hangers/Springs/Axles
routemaster
Deming
Posted: 09/12/21 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
On my 2017 Hartland, the 8k axles have moved off the center of frame to the road side by 3/8inch.
Now the hangers welded on to the frame have a 2.010inch wide gap, the springs have a eye dimension 1 3/4" wide so the hangers have been squashed down to the eye of the springs not a 100% face location would this be normal not good engineering.
The axle perches have a pitch for springs at 68.500" and the center of the frame "I to I" at 68.844" therefor the spring taper inwards.
I have been trying to find out with no joy whether the wrong hangers were welded on or they installed 1 3/4" over 2" springs?
Could I install 2" springs to help stiffen this nightmare?
To top it off I have done the string test and I have a bent "I" frame going up into the coach by +3/4" at the front axle.
Any help.
Den.
2017 Landmark Arlington 365
2015 Silverado LTZ 3500 c/c LWB.
GMH
Canada
Posted: 09/12/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t know if this helps. I just had everything replaced and upgraded the springs on my Cougar 26sab. Here are a couple of before pics. Hangers all look straight and square.
JIMNLIN
Oklahoma
Posted: 09/13/21 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you need to find a big rig trailer repair shop in your area and let them make a call on what issues that trailers suspension/frame rails have.
bolljl
Fulltimer
Posted: 09/13/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Highly recommend checking into https://www.morryde.com/products/independent-suspension-system/ that replaces Hangers/Springs/Axles with independent suspension system.
2015 RAM LongHorn 3500 Dually 4X4 CUMMINS
2013 Lifestyle LS35SB, MORryde IS System
AIRSAFE, Air Hitch
laknox
Arizona
Posted: 09/13/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Another option is the Roadmaster Comfort Ride system. Uses slipper springs and shocks.
https://www.roadmasterinc.com/products/travel_trailers/comfort_ride.php
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
buc1980
houston tx
Posted: 09/13/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Change to IS system and get ready of the head ache .
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
TXiceman
Full Time RVer
Posted: 09/13/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Been running the Mor/Ryde IS for 8 years and love it. Greatest thing available for RVs. It is not cheap but rides so much better.
Ken
Amateur Radio Operator.
routemaster
Deming
Posted: 09/13/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
I am planning to take her to AZ to have the frame pulled down and they will reinforced the frame. I would love IS maybe later.
Thanks.
Den.
