mellow
Salisbury, MD
Happijac's are not so great on new trucks with all the plastic and aluminum, torklift is the way to go on them.
Congrats on the new camper! I would say post pics but on this forum its a royal PIA.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
jimh406
Western MT
Photoposting isn’t that hard any more. Follow the instructions on the site that was made for posting pics. http://photoposting.is-great.net/?i=2
greenno
Clairemont Cal.
Totally agree on the TV antenna (aka mushroom) every time I go off road I'm just waiting for it to catch on a tree branch. 3 years so good so far...
deltabravo
Spokane, WA
FireGuard wrote: To nitpick something, they could have installed a low profile A/C and made a shorter TV antenna it it would have reduce the overall height by 6-8”.
Ultra low profile A/C is only about 4" shorter.
I've had one on order from a RV supply wholesaler since about May. No idea when that warehouse will get it. It's the same place that supplies RV dealers all over the country with parts and accessories.
Here's the one I installed on my 2010 AF 811
daily double
ketchum ok.
I purchased an 8 month old AF from an individual and on the way home I had trouble closing the entry door. I heard Boardman rv in Pueblo West Co was a big AF dealer so I stopped in to see if I could get it fixed. The salesman informed me "we don't work on what we don't sell".I intend to call Northwood to see if any of their dealers work on all AF T/Cs.
Bedlam
PNW
Make sure the camper is sitting level in the bed. If it is uneven on one corner, it may be twisting the frame. You can check this out by disconnecting the turnbuckles and raising the camper slightly off the bed. If the door now clears the opening, start looking what may be between the camper and truck that is causing it to twist.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
deltabravo
Spokane, WA
Define "trouble closing the door".
Find where the problem is and see if you can fix it yourself.
It might be as easy as adjusting the striker plate on the door frame.
JimK-NY
NY
deltabravo wrote: Delam problems I've seen are all because people didn't keep them from leaking.......
Do you have to spend a great deal of time and effort making sure your car does not leak? Why is it that we accept this strange notion for RVs? They should be built so they do not leak and so they do not need constant inspections trying to avoid small, hidden leaks that create havoc.
Slymer
Ontario, Canada
VERY good point. Especially on point considering the prices these units are going for. I am waiting for someone to develop a clear spray sealer that you can use annually around all your clearance lights, etc. Would be so much easier than replacing caulking.
d3500ram
Colorado
Quote: .... I am waiting for someone to develop a clear spray sealer ....
As seen on TV....
But wait, there's more...
(The above links are meant to be for amusement purposes only. No direct evidence or correlation to an actual clear spray sealer for the use on RV's to make them totally and entirely waterproof is express or intended. )
