RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel lube
 > 5th wheel lube
Diamond c
West ky
Posted: 09/12/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
This may have been covered before but I can’t find it. I drive a truck for a living and grease my 5th wheel at least once a month. I’ve also have been looking at other folks that have a 5er and haven’t seen anybody that greases their hitch. My question is why not? We have just purchased one and will be picking it up sometime in the next 2 weeks so I really need to know. Thanks.
GMH
Canada
Posted: 09/12/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
I believe it should be greased if it is metal on metal. I use one of those thin plastic or teflon discs that eliminates the need for grease. I guess I should grease the jaws that grip the kingpin though?
TXiceman
Full Time RVer
Posted: 09/12/21 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use one of the plastic lube disc. I do add some grease to the jaws on the 5er hitch.
Ken
Amateur Radio Operator.
ETCrockett
Greenwood, IN
Posted: 09/12/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I use the lube plate like others have mentioned. However, I also use grease on the jaws, kingpin, and on the bushings the hitch head pivots on.
Eric & Andrea
2016 Jayco Pinnacle 38FLSA
2009 Ford F450 DRW
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/12/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I'm with the others, Lube Plate and Grease on the Jaws.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Diamond c
West ky
Ok thanks that makes since I hadn’t thought of that. We tried them on our trucks at work for a while but they didn’t hold up but I can see we’re they might work better for this.
Second Chance
Wherever...
Posted: 09/12/21 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I get multiple years out of each $12 - $15 lube plate on our 15K fifth wheel. As for the hitch, PullRite specifies what lubricants to use on each part of the mechanism underneath the plate (jaws, pinion, latch, springs, etc.). I just follow the manual on that and put a thin film of all-purpose grease around the pin where it makes contact with the hitch and latch parts.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
handsome51
Baytown
Posted: 09/12/21 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I use the white teflon disk and grease the pin and jaws on the hitch
stickdog
Somewhere, USA
Posted: 09/12/21 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
1) Teflon disk
2) white lithium per manufacturer on uprights
3) spray heavy duty lube
On jaws
4) medium duty grease in the zerk fitting on the pivot bar.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
JIMNLIN
Oklahoma
Posted: 09/13/21 05:24am Link  |  Quote  |  Print  |  Notify Moderator
In the beginning we used red chassis grease on the hitch top plate. Then the white plastic nylon disc became available so no more grease stained clothes/hands.
Make sure your hitch mfg recommends using one.
You'll see some 5th wheel rv trailer owners use nothing or some type of spray on lube.
My 11400 lb 5er has around 2200-2400 lbs on the plate ...nothing like the load your OTR rigs top plate carries ...or the miles per year of use.
 > 5th wheel lube
