RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel lube
 > 5th wheel lube
thomas201
Eastern Panhandle WV
Posted: 09/13/21 05:46am Link  |  Quote  |  Print  |  Notify Moderator
I also came from the big truck world. The plastic plates are great on our 5ers, no so much on the big trucks. However, grease works great, but as you know it is messy.
ford truck guy
Pennsylvania
Posted: 09/13/21 06:22am Link  |  Quote  |  Print  |  Notify Moderator
YUP, another Lube Plate User here.
That is just an example of what is available
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MNRon
Tennessee
Posted: 09/13/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Another benefit to my Pullrite Superglide, the king pin is locked so it doesn’t swivel. It’s recommended to lube with wd40 - not nearly as messy as grease. Ive done this for ~7yrs and >50k miles and all is good. I do clean up and check the hitch every year or two.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
garyp4951
TN
Posted: 09/13/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I had to get the thinner lube plate so my hitch jaws would lock correctly.
Cummins12V98
on the road
Posted: 09/13/21 07:22am Link  |  Quote  |  Print  |  Notify Moderator
What hitch?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 09/13/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Yes. The lube plates come in 2 or 3 different thicknesses, so you need to get one that will work with your hitch. I remember reading a number of years ago, where a guy ended up ditching his hitch because the fit was so tight that NO lube plates would work and he hated having to grease the hitch plate. AFAIK, most mfrs do have a recommendation for which plate to use.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
 > 5th wheel lube
