RV.Net Open Roads Forum: Solar system with both 12v and AC inverter
 > Solar system with both 12v and AC inverter
ApexAZ
Gilbert, AZ
Posted: 09/12/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
So we should be picking up our new Fuel Toyhauler on Saturday and we need to install a solar panel kit with inverter.
I have about a zillion questions regarding solar, but my most pressing question is in regards to AC inverter and DC converter.
I have to use a CPAP machine at night and my particular model doesn't seem to support AC Inverter supplied power. I plan to call them tomorrow to confirm and find out why, but based on their battery use instructions, they say a DC-to-DC converter is needed and AC Inverter is not recommended.
We also want to install an AC inverter to be able to use tv, small appliances, chargers, etc.
So my question is this: could I connect a single battery to both an AC Inverter and a 12v outlet in the bedroom to be used specifically for my CPAP, or will this cause issues having two different types of circuits drawing from the same battery?
Hopefully that makes sense.
DrewE
Vermont
Posted: 09/12/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
There's no problem at all with having the same battery bank supplying both 12V loads and an inverter. That's the most common setup for RVs with an inverter, and in my opinion the most sensible, as it allows you to use all the available battery power in whatever way is necessary without artificial divisions.
Your CPAP machine would probably be just fine with a pure sine wave inverter; indeed, it would have no way of "telling" that the power is from an inverter and not a generator or the utility. A modified sine wave inverter is a different story altogether. That said, the DC to DC converter will probably be more efficient overall (you'll waste less power than using an inverter and the usual AC power supply).
ApexAZ
Gilbert, AZ
Posted: 09/12/21 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent. Thank you!
In a video I watched, the guy moved his lithium battery to inside the storage compartment and closer to the inverter.
Is this a fire hazard?
theoldwizard1
SE MI
Posted: 09/13/21 02:44am Link  |  Quote  |  Print  |  Notify Moderator
There are 2 types of lithium batteries. The large ones that you would purchase are very safe/can not explode/burn.
IMHO, all-in-one devices (solar charge controller, battery, inverter) are NOT the best "bang to the buck". Look up Will Process on YouTube. Lot's of good videos on solar, batteries and inverters.
wanderingaimlessly
Buggs Island lake
Posted: 09/13/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
Your TH likely already has a Pure sine wave inverter, for powering TV's or the fridge. In my Winnie I simply tapped the TV outlet in the bedroom with an extension cord for the CPAP on nights we are not connected to shore power.
D.E.Bishop
Eagle Rock, CA
Posted: 09/13/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I'll second Drews suggestion.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
ApexAZ
Gilbert, AZ
Posted: 09/13/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I should learn more from the tech guys when they do the walkthrough on Saturday, but the salesman didn't think so. I am not sure if the TV is 12v, or if maybe the generator has an inverter connected to it somehow? I really have no idea. My understanding is the generator needs to be running to power things like the AC, tv, outlets, etc. So maybe it does have an inverter and the salesman just doesn't know?
The spec sheet only lists a 55A converter and 30A shore power. I'm not even sure why those figures are different, which tells you how ignorant I am on the subject lol. I'm currently drowning in solar info and looking at brands like Victronic, Renogy, GoPower, etc. It's overwhelming.
dodge guy
Bartlett IL
Posted: 09/13/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Check out DIY Solar with Will Prouse on You Tube. He will have all the answers you need. Very good for beginners.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
DrewE
Vermont
Posted: 09/13/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
The 55A for the converter is the maximum 12V DC output current (for charging the battery and powering 12V devices when there's 120V AC power available). The 30A shore power is a 30A 120V AC connection. 55A at 12V DC is 660W of power that the converter can, well, convert. The shore power connection is capable of supplying up to 3600W. More generally, for the same power, you need a proportionally greater current at lower voltages.
If you need to run the generator or be connected to shore power to have 120V AC electricity available, then you don't have an inverter working.
wanderingaimlessly
Buggs Island lake
Posted: 09/13/21 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
I would not worry too much, you do have simple options.
IF the trailer does not have an inverter already, you can also power most cpap units off of 12 volts. 12 volt cords
If your machine has a "brick" in the regular power cord, chances are that it actually runs on 12 volts, making these cords a simple solution.
