RV.Net Open Roads Forum: Tech Issues: Troubleshooting Propane Problem
 > Troubleshooting Propane Problem
strollingbones
Frederick, MD
Posted: 09/13/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Hi Folks,
I have a propane leak that I'm trying to get my arms around. My local RV repair/dealership is overbooked with sales and repairs during covid, and they can't get to me in a timely manner.
The leak is occuring between the propane tank and the regulator. There is an aftermarket fitting (installed by a previous owner) there called an "oil drip leg." It's purpose is capture impurities in the propane before it reaches the regulator. These gizmos are not common on RVs.
I think I have narrowed the problem down to these scenarios:
1) It's full.
2) It was attached with pipe dope rather than yellow teflon tape
3) Both of these things at once
So here are my questions:
1) Can I just remove this %$#@! thing altogether? Most motorhomes seem to get along fine without it
2) If I remove this thing, can I clean it out and reattach it? Or does it have to be replaced?
Thanks in advance for your assistance!
2oldman
NM
Posted: 09/13/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
remove it
jdc1
Rescue, Ca
Posted: 09/13/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I've only owned a dozen or so RV's. Never have I seen a VLP on one.
Boon Docker
Posted: 09/13/21 11:49am Link  |  Quote  |  Print  |  Notify Moderator
It is not needed on an RV, I would just remove it.
They are used mainly in home installations where the appliance (furnace, water heater) has a lot more propane consumption than in an RV.
Roger10378
Goodrich, MI.
Posted: 09/13/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
I would drain it and reinstall with new tape. They are not common in RV's but there are posts on here complaining about propane not getting to an appliance and a black sticky substance in the line.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
bgum
South Louisiana
Posted: 09/13/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
It may have been put on there because the prior owner had a problem with junk in the propane. Remove it, clean it, and reinstall it with the correct tape.
2oldman
NM
Posted: 09/13/21 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well, there you have it. 3 nays and 2 yeas. Don't you love internet advice?
Boon Docker
Posted: 09/13/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
To settle the nays and yeas.
Remove it, if it is full of oil clean and replace, if no oil leave it off.
RLS7201
Posted: 09/13/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Could it be that you have a diesel coach with a propane generator? If so, leave that oil drip leg in the system to keep oil out of you liquid fed propene regulator on the generator.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
strollingbones
Frederick, MD
Posted: 09/13/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your advice!
