RV.Net Open Roads Forum: Tech Issues: Troubleshooting Propane Problem
 > Troubleshooting Propane Problem
Dusty R
Charlotte Michigan 48813
Posted: 09/13/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
When you have it apart take a close at the threads and see if they are in good shape.
Bobbo
Wherever I park
Posted: 09/13/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Gas certified pipe dope is better than gas certified tape. But, remove it. I like Permatex.
Bobbo and Lin
Posted: 09/14/21 04:35am Link  |  Quote  |  Print  |  Notify Moderator
Ok I goofed with my last response so it went to a wrong thread. or at least it appears that happened.
Looks like a brass to steel coupling. the two metals have different coefficients of expansion as they get hot/cold. so the connection can fail under pressure.
I'd replace the steel parts with brass and the proper tape.. Precise length is not important only the diamater and thread.
Second that looks to be a "Home brew" Fix for a problem that likely did not exist. Some of the Home brew things I've seen seriously scare me.
Tom_M
New Hope, MN
Posted: 09/14/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
A fellow camper was ready to replace his fridge when it stopped working. When he disconnected the propane line oil ran out. Fix the leak and replace it. It's good insurance.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
