RV.Net Open Roads Forum: Class C Motorhomes: Koni or Bilstein?
 > Koni or Bilstein?
EMD360
Arvada, CO
Posted: 09/13/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
We had a heavier than normal load last weekend and I rode in the back where the bouncing and rattling and sway were very uncomfortable. Even without the load I think the ride is too rough I’m thinking of having the shocks replaced with top of the line versions. I’ve read that both Koni and Bilstein are great. As you know parts are hard to get right now. Should I get whatever they can get of these two or specify?
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
MDKMDK
Lockdown Gulag
Posted: 09/13/21 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
They're both good. Go with whatever you can get.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
EMD360
Arvada, CO
Posted: 09/13/21 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Should I add Sumo springs?
IAMICHABOD
Sunny So Cal
Posted: 09/13/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
This has come up many times here and it seems to be equally divided,the Koni shocks are about twice the cost and get some good reviews and I know of One Member that would gladly exchange his for the Bilsteins that he used on a previous RV,expensive is not necessarily better.
The Koni shock was not in production for Class C when I wanted new shocks but even now I would not opt to buy them.
I will recommend the Bilsteins they did not make the ride any harsher and stopped the porpoising and the ride is smoother and cornering has lot less body roll.
I have used Bilstein shocks on all my vehicles for many years and have been pleased with their performance.
* This post was edited 09/13/21 02:05pm by IAMICHABOD *
Former El Monte RV Rental
Buying A Rental Class C
MDKMDK
Lockdown Gulag
Posted: 09/13/21 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I plan to, at some point, add Sumo Springs for curb roll.
bobndot
Posted: 09/13/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed , Either or Bils or Koni’s. End result is the same. I have used both.
Not so sure about Sumo’s or if HD sway bars would accomplish the same thing. Don’t really know.
pnichols
The Other California
Posted: 09/13/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Some Koni shock types compete with Bilstein shock types - but those Koni types would probably be more expensive than the equivalent Bilstein models ... so in that case the Bilstein models might be the better price choice.
HOWEVER, for smaller/lighter-weight motorhomes that do not heavily pre-load the rear springs of the chassis that they're built on ... the special Koni shock that you want would be their FSD shock ... which I don't think that Bilstein offers an equivalent to.
The Koni Frequency Selective Damping model ("FSD") shocks automatically adjust themselves so as to offer low or no resistance on quick bumps like roadway potholes and cracks. The rest of the time, Koni FSD shocks automatically adjust themselves so as to offer the regular stiff shock damping control that is needed for slower occuring forces applied to the springs.
As an example regarding our 24 ft. slideless Class C on it's overkill Ford E450 chassis - it had a lot of pounding in the rear from potholes and cracks. That pounding has been radically reduced because of the Koni FSD shocks I had installed in the rear several years ago.
The rest of the time, the stability and control with the Koni FSD shocks remain about the same as they were with the stock Ford OEM shocks in the rear of our a small Class C on an E450 chassis.
Phil, 2005 E450 Itasca Spirit 24V
EMD360
Arvada, CO
Posted: 09/13/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure our Winnie 25b would be considered light weight. While it’s in the shop I’m also having an alignment and having the tires checked for wear.
pianotuna
Regina, SK, Canada
Posted: 09/13/21 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
When I resprung my Rv, I added a leaf and replaced the defunct air bags with Timbrins
Regards, Don
DrewE
Vermont
Posted: 09/13/21 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
I've been happy with my Koni FSDs; they seem to work as advertised. I do have Ride-Rite air helper springs in the back that help a lot with the stiffness of the suspension there (aiding in controlling sway and bouncing). That's not to suggest the motorhome rides like a luxury car.
If you're a DIY type, replacing the rear shocks in the Ford E-series chassis is a piece of cake. Replacing the front ones is considerably less convenient; access to the top nut for the front shocks is difficult. I found a flex-head ratcheting box-end wrench the best tool for the job, or perhaps more accurately the least terrible tool.
If you're getting bumping and clunking in the steering wheel, also check the tie rod ends for looseness and the radius arm bushings.
 > Koni or Bilstein?
