RV.Net Open Roads Forum: Class C Motorhomes: Koni or Bilstein?
 > Koni or Bilstein?
EMD360
Arvada, CO
Posted: 09/13/21 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Hopefully the entire suspension will be checked. Shop advice was try the sumo springs first as pulling the leaf springs to add another is expensive. I’m not very DIY when it’s automotive.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
EMD360
Arvada, CO
Posted: 09/16/21 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
I’m waiting for parts now. Brought the RV home in the meantime. Will need the rear brakes and alignment. Optional is the shocks. They said KONI and Bilstein were about the same price which leads me to believe they are ordering the Bilstein. I decided against the helper springs. Very expensive and not sure if the other upgrades will help the ride enough. But the heavy duty Helwig sway bar was only about $500 with labor so I’m having that installed. A little over $5000 for all. It may be expensive but I know they do good work.
pnichols
The Other California
Posted: 09/17/21 12:23am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm ... it sounds like they may have been quoting you standard KONI shocks versus Bilstein shocks, instead of KONI FSD shocks against the Bilsteins. FSD shocks should be priced higher than Bilstein shocks. [emoticon]
Phil, 2005 E450 Itasca Spirit 24V
crawford
Dandridge Tenn.
Posted: 09/19/21 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
anything after 2004 Ford put on Bilstein shocks changing shocks won't help at all.But sometime if you at some water to your water tank it will help at lot.
Change from a c class to a A class Georgetown 07 triple slide
 > Koni or Bilstein?
