RV.Net Open Roads Forum: Tech Issues: Lithium cost keep dropping!
 > Lithium cost keep dropping!
Page of 6
time2roll
Posted: 10/08/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Standard shipping from China right now is 90+ days. If it is the regular 75 days promised I would start a dispute at 76 days.
Here is a few legit sellers. Qishou
Docan
Luyuan
* This post was edited 10/08/21 07:28pm by time2roll *
675w Solar pictures back up
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 10/08/21 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
So the 100 amp hour battery is actually 120 ampere hours with the bottom 20 amp hours Forbidden Planet? What is making my eyebrows rise?
Tom_M
New Hope, MN
Posted: 10/09/21 04:46am Link  |  Quote  |  Print  |  Notify Moderator
This is true for what is considered a "drop-in" battery which has a built-in BMS. Without a BMS the battery would be quickly destroyed.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
jaycocreek
Idaho
Posted: 10/09/21 05:27am Link  |  Quote  |  Print  |  Notify Moderator
The Chins 100ah battery is actually 104ah for $359..
Chins $359 100ah battery tear down..
StirCrazy
Kamloops, BC, Canada
Posted: 10/11/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
What is the USUABLE amp hours of a "100 amp hour" lithium battery?
Or is it hypothetical like solar panel wattage as measured on the planet Mercury?
Sweet spot is up to 80% for 4000 to 6000 cycles.
100% maybe 3000 cycles or almost 10 years for daily cycling.
This rating drops you to 80% capacity. Possibly still very usable.
For many of us it could prove to be the last battery we buy.
depends on the brnd, some advertise 5000 @ 100% dept of discharge and up to 8000 or more if you stay in that 80% so to me its 3-5000 depending on the battery at 100% and if you use less you get bonus rounds. but your tight even if you max out on the 100% thats just the figure to get to 80 to 90% capacity and then you can go a lot linger like that.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
MEXICOWANDERER
Posted: 10/11/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Life cycle I understand well.
But a lithium battery contains "x" number of amp hours. Let's use the 20 hour rate...
But a certain percentage of those amp hours are "no touchee" because any further drawdown would permanently damage the battery.
The internal BMS prevents unintentional drawdown past the safety minimum.
Now for my ongoing question...
Yes or no
Do the advertised amp hour claims for these batteries include or exclude mo-Touchee amp hours?
road-runner
Oregon
Posted: 10/11/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
YES: The advertised amp hours do include the no-touchee amp hours. For maximum charge cycles, there are recommendations to not touch the top 10% either, leaving 70% usable. Compared to 50% recommended for lead acid batteries. Lots of discussion about this on solar energy forums.
2009 Fleetwood Icon
jaycocreek
Idaho
Posted: 10/11/21 10:04am Link  |  Quote  |  Print  |  Notify Moderator
If watch that Chin's $359 video I posted the link to,It shows Will drawing down the 100ah Chins battery to zero and 104 amp hours through his tester..He also did one on the Zoom battery with the very same results..104 amp hours to zero/dead dark 30......LOL
time2roll
Posted: 10/11/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Yes or no
The rating is the energy that you can actually pull from the battery.
This is the same as people go round and round about propane cylinders and the 80% fill cut-off.
Now having said that, there are sellers in CN selling batteries that do not produce the rated power. Best to buy from a reputable and verified supplier.
BFL13
Victoria, BC
Posted: 10/11/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes or no
Last go-round on all this, it came out that "energy" and "power" wording had to watched like a hawk. eg, when you get down to 50% AH you are more than half way down in energy remaining.
There was some jiggery-pokery about how they get the AH rating. Instead of using a 5a draw for 20 hrs to get 100AH, some said they draw 100a for 1 hr and then do some kind of fudging between watt hr and AH curves to get a range.
Some said 120 vs 100 depended on the type of cell where prismatic cells needed the cushion at the low SOC.
Most said they didn't care about the exact amounts for how they camp and they get what they want from their LFPs using ball park figures--common sense!
Mex will get a bad headache if he wants to "go there" . Lie down till the urge to figure out LFPs goes away!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Page of 6
