RV.Net Open Roads Forum: General RVing Issues: cleaning 7-pin receiver connector on truck
 > cleaning 7-pin receiver connector on truck
Omrod
Wisconsin
Posted: 09/15/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I keep getting "Trailer Connected" message in my truck, I was guessing the pins were somewhat corroded. I have sprayed dielectric spray and I do not want to short out anything by using a metal brush.
So what is the best way to clean the receiver on my truck?
I tried doing a search and came up with nothing. Thanks for any help!
Omrod
2015 Chevy Silverado HD
2021 Grand Design Imagine 3250BH
Equal-i-zer Hitch
prichardson
Lafayette, La
Posted: 09/15/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Fine emery board or if you are near your trailer, plug in and unplug several times.
corvettekent
Marysville, WA
Posted: 09/15/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
When I get that message I just disconnect and connect the trailer plug a few times and the message goes away.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Dick_B
Palos Heights, IL USA
Posted: 09/15/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
In the old days I used to drill out the female connectors to get rid of corrosion. Also try spraying Corrosion X into the male connectors.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Matt_Colie
Southeast Michigan
Posted: 09/15/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Omrod,
I think you should try to find out what "Trailer Connected" really means when the trailer is not connected.
That would tend to indicate that there was some connection where none should be. Yes, it is probably corrosion that is causing it and it would lead me to think it was in the socket on the truck.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
valhalla360
No paticular place.
Posted: 09/15/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Is there a lot of crud inside?...might hit it with a power washer. (Shouldn't be an issue but give it a day or so to dry out before towing if you are worried).
Shouldn't be any harm as the spray going down a wet salty road is far worse.
After pressure washing, you should be able to differentiate dirt from corrosion.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JRscooby
Indepmo
Posted: 09/15/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
When was the last time you cleaned your battery terminals? Disconnect batteries, brush trailer outlet, blow out any shed bristles, spray with dielectric, clean and re-connect battery.
Omrod
Wisconsin
Posted: 09/15/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. What happens is . . . I'm traveling down the road, pulling my camper I and get: ding, ding, ding and a message saying "Trailer Connected". I dismiss the message and a little while later it does it again. It gets annoying after a while. My battery is fine no corrosion there and it doesn't look real corroded inside the plug. I was hoping there was "magic" spray with baking soda or something.
schlep1967
Harrisburg, PA
Posted: 09/15/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
If you disconnect the truck battery and then use your metal brush, then ensure there are no metal brush parts stuck anywhere, you shouldn't be able to short anything out.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Gdetrailer
PA
Posted: 09/15/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
Use small piece of sandpaper folded up a few times or a "Emory board" like one would use for fingernails, not a metal brush, then there is no issue of anything getting shorted.
