RV.Net Open Roads Forum: General RVing Issues: cleaning 7-pin receiver connector on truck
 > cleaning 7-pin receiver connector on truck
mdcamping
CT
Posted: 09/16/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I've used a pocket screwdriver and scratch up the terminals
Mike
07 Toyota Tacoma,Double Cab, Max Towing 6,500lbs GCWR 11,100lbs
2011 Jayco X20E, Pro Series 800lb Weight Distributing Hitch
Husky Sway Bar, Prodigy Electronic Brake Control
McKesh Mirrors.
Where we have camped
Gdetrailer
PA
Posted: 09/16/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
I'm not much smarter than a box of rocks, but have used Dielectric grease on hundreds of light cords for millions of miles for decades. And sense I started, the only issue I have had is careless handling. Start with tight, clean connections. A little of the grease about every 10-20 unhooks. I assume that like any grease, it will keep moisture, therefore corrosion off the contacts. And because it is non-conductive, I do not need to worry about it causing short circuits.
In the case that is "working" for you, basically you are depending on the contact springs to be strong enough to displace enough of the dielectric grease from the contact surface to make a electrical connection.
Sometimes works, sometimes doesn't.
Whatever contact is being made is compromised electrically and adding needless resistance to the equation.
I am just trying to correct the old wives tales that dielectric grease is a magical cure all for everything electrical.
It isn't.
It isn't the proper tool to use if the goal is to get the best electrical contact.
Dielectric grease as mentioned on the website I linked typical uses are for preventing electrical "leakage" in high voltage situations like your spark plug boots and distributor boots.
The proper tool is two of the greases I mentioned (Oxgard or No-Alox) and you just apply that to the contact surfaces only, it will not run or creep and it is specifically made for doing the exact thing you want which is to keep moisture away from the contact surfaces.
agesilaus
North Florida
Posted: 09/16/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
When I said tiny I meant very small a blob about 1/8 in by 3/16 in on the end of the contacts. Not enough to travel down the metal blade
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Gdetrailer
PA
Posted: 09/16/21 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Hmmm...that is new info for me, I saw one of the electrical guru's advocating it's use on these connectors and just assumed (yes I know) that he knew what he was talking about. A tiny amount on the end of the truck end connector certainly abolished the lost connection messages for the next couple hookups.
Not all electrical gurus understand what "dielectric" means.
Merriam-Webster Dictionary definition Link
dielectric noun
di·?elec·?tric? di-?-'lek-trik
: a nonconductor of direct electric current"
Now, ask a Electronics Tech (like myself) that is familiar with the way capacitors are made and they (like myself) will tell you that a dielectric (electrical insulating) material is placed between two conductive plates which forms a capacitor...
Electrical leakage through the capacitor's dielectric insulation means that cap is shot and needs replaced..
Rather than depending on a grease or spray to fix intermittent electrical connections, it is best to simply scrape or sand all tarnish from the contact surface.. Small pocket knife blade, small flat blade screw driver, sandpaper folded over a few times or even a Emery board cut to fit in the contacts.
If it is shiny, it will work, anything else less than shiny and all bets are off.
I run my trailer connections 100% dry, no grease, no sprays. I take a piece of sandpaper folded over a few times and burnish the contacts till shiny.
Then insert plug into socket and I wiggle the socket a few times, any grit from the sandpaper leftover from the will help clean the socket contacts..
Thermoguy
Graham, WA
Posted: 09/16/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting comments. I surf other forums and dielectric grease was always recommended as the solution for this problem. I can tell you only from my experience, since using the grease, I have this error less than I did using a dry connection. I will continue to use it even if it is the wrong product, only because it works. Thanks for the definitions and experience from electricians and electronic techs.
PA12DRVR
Back in God's Country
Posted: 09/17/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
"Interesting comments. I surf other forums and dielectric grease was always recommended as the solution for this problem. I can tell you only from my experience, since using the grease, I have this error less than I did using a dry connection. I will continue to use it even if it is the wrong product, only because it works. Thanks for the definitions and experience from electricians and electronic techs."
My experience as well. The emery board, sandpaper, etc probably helped, but after doing that AND applying the dielectric grease, the repeated "trailer disconnected / trailer connected" cycle went away and has been gone for 2+ years now vs. the usual 1-2 weeks after using ONLY the emery board / sandpaper / wire file solution.
CRL
My RV is a 1946 PA-12
Back in the GWN
dedmiston
The West
Posted: 09/17/21 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have no dog in this hunt, but I've definitely learned over the years to beware of anyone telling you how wrong you are.
That level of hubris doesn't typically pan out.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
JRscooby
Indepmo
Posted: 09/17/21 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
The metal to metal contact is all that will carry the current, even if nothing is used. And the odds the friction of connecting will scrape off the grease is much higher than it will remove enough of any corrosion
Any corrosion will also compromise the contact. And it will also reduce the spring pressure. Cleaning likely will restore contact, but every time a abrasive is used, there is less metal, weaker contact.
There is 2 things that can go wrong when you plug in the light cord. Bad contact, and just as bad if not worse, contact between the conductors, or a short.
When mine is covered with dielectric grease, I plug in, the contacts slide on each other, the grease will stack up in bottom of socket. I would be willing to bet the magic you recommend will do the same thing. But, and to me a big but, the dielectric, being non-conductive, will not cause a short.
I would add that your recommendation would likely reduce problems in something like a crimp connection, where the fit tightens after the wire is in place.
* This post was edited 09/17/21 04:06pm by JRscooby *
mdcamping
CT
Posted: 09/28/21 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Mike
well I had to take my own advice. Just returned from a trip to NY, anyway when I was pulling into the campground noticed the trailer controller read NC. Put my hand on the plug which felt very warm, tried plugging & unplugging several times and no luck. So after setting up camp I then dug into my tool bucket and pulled out the small screwfriver and did what I have done in the past. I also found that works well is the file like teeth on my needle nose pliers, worked great on the male connections. I was back in Business!
Been awhile since I cleaned the terminals as it was overdue [emoticon]
Mike
* This post was edited 09/28/21 07:42am by mdcamping *
