RV.Net Open Roads Forum: Class A Motorhomes: Dashboard gauges failure
 > Dashboard gauges failure
Cbmbdm
New jersey
Posted: 09/15/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Hit big bump, heard something start bumping around under passenger side feet. At same time lost speedometer, gas gauge, tach, oil press, engine temp trans temp. Is there a module that may have fallen off/out. Thanks
rgatijnet1
Posted: 09/15/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
You may have a fuse box/electrical panel under there that needs to be checked.
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 09/15/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Had something like that happen in the past with a motorhome. Hit a big bump and A/C quit and it was hot. Bump had dislodged a fuse. Pushed back in and all ok.
dodge guy
Bartlett IL
Posted: 09/15/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a Class B van or a Diesel Pusher. Need some more info.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
DrewE
Vermont
Posted: 09/15/21 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
It could also be a ground connection that broke/bounced loose, or just a connector to the dashboard cluster.
wolfe10
Posted: 09/16/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
YUP.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Cbmbdm
New jersey
Posted: 09/16/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
2019, Newmar, Baystar, Ford v10
dodge guy
Bartlett IL
Posted: 09/16/21 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Ok that helps. I would check to see if something moved and unplugged the plug to the cluster.
