RV.Net Open Roads Forum: Class A Motorhomes: HWH 610 Leveling system.
 > HWH 610 Leveling system.
Tom/Barb
Oak Harbor, Wa
Posted: 09/16/21 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Our Jacks will deplete the air when the system is activated, then quit.
ignition is on, Acc.,, brake set, ground is nearly level.
you push the ( ON/Auto ) the control panel will light, and the red light will illuminate, the air will dissipate. ( go to 0)
then the pump will not Start as usual. you can hear the solenoids click as usual. but no pump noise or pumping action.
key pad shows a yellow light on the pad.
enblethen
Moses Lake, WA
Posted: 09/16/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Check to insure large cable to pump has power to it.
Should have a solenoid on it.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom/Barb
Oak Harbor, Wa
Posted: 09/16/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Done,, no change.
enblethen
Moses Lake, WA
Posted: 09/16/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Which yellow light comes on?
Hope this is correct manual. Manual
Tom/Barb
Oak Harbor, Wa
Posted: 09/17/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
top center
Nope.. mine is MI.1126/MP05.5001/CHD-S
09APR99
enblethen
Moses Lake, WA
Posted: 09/17/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Your manaul reference is operators manual. One I posted is troubleshooting.
Top center appears to be excessive slope is that correct?
Tom/Barb
Oak Harbor, Wa
Posted: 09/17/21 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
the coach is parked at our home spot, = level
MountainAir05
New Mexico
Posted: 09/18/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Take a broom and move the level sensor under your Rv. Mine is located about center. On the last page of your manual. Mine got stuck with slush one time and cause all sort of issue. I put a deflector in front of it so maybe it would not happen again.
Tom/Barb
Oak Harbor, Wa
Posted: 09/18/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
I don't believe we have that type of sensor
our 2000 coach has a sensor under the sink
to recap
our system will start when the HYD button is hit twice.
it will run until all air pressure is gone. ( it is supposed to stop when the pressure is 45 pounds)
when the all pressure is depleted the pump will not start
all the keypad buttons are active, you can hear the selenoids working when the buttons are pushed.
all cylinders are fully retracted (up)
all red lights are out, they usually light as soon as each cylinders start to extend
The HWH folks are useless they tell you there is a trouble call in,,but they never call
* This post was edited 09/18/21 01:47pm by Tom/Barb *
enblethen
Moses Lake, WA
Posted: 09/18/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
The one in the center is the one for the leveling indicators.
Jumper between the large posts on pump motor solenoid. See if pump starts.
If it does check the small posts for continuity.
