RV.Net Open Roads Forum: Class A Motorhomes: HWH 610 Leveling system.
 > HWH 610 Leveling system.
Tom/Barb
Oak Harbor, Wa
Posted: 09/18/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
The one in the center is the one for the leveling indicators.
Jumper between the large posts on pump motor solenoid. See if pump starts.
If it does check the small posts for continuity.
now the yellow light is out.
why is the air in the system completely depleted ? it is suppose to stop letting the air out when the pressure is 45 PSI.
the pump never starts. jacks stay up, never moves
double checked .. all fuses are good.
jumper the solenoid "A" to +12 volts. nothing happens.
enblethen
Moses Lake, WA
Posted: 09/18/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
One of small terminals is ground. Other pin should be control 12 volts DC. Not sure which is pin A.
Did you check for resistance between the small pins on pump solenoid?
Did you find the main control unit? There is several fuses there including one for pump control.
Has there some recent battery work done?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom/Barb
Oak Harbor, Wa
Posted: 09/18/21 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Both solenoids has been checked for operation. all terminals cleaned, and tightened.
Yes the entire house battery system has been replaced, to include lithium batteries, a 12 to 12 /30 amp charger, a smart shunt (500) and a voltage gauge/ monitor system.
all electrical have been working normally.
the HWH electrical power is supplied +12VDC. and proven at the control box.
The HWH jack system is on the chassis battery buss.
if the Keypad works it must have system voltage.
the system will dump the air, it must have voltage "power"
enblethen
Moses Lake, WA
Posted: 09/18/21 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
It just acts like there is no control power to the pump.
Tom/Barb
Oak Harbor, Wa
Posted: 09/18/21 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
EXACTLY
I now have three light showing.
a red power (HYD)
I white (Travel)
Yellow Center top showing it is level in front
next step. send it in for system check ,, HWH does have that service.
but it is the weekend..
Tom/Barb
Oak Harbor, Wa
Posted: 09/20/21 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I've completed a lesson in frustration the past day or two..
HWH has the poorest customer relations I have ever seen..
first the gal will put you on hold until it times out
if you ever do gain access, she can only tell you to be on a call waiting list.. expect to be waiting a couple months.
If you try to order a part, the people have a 2 week wait on a waiting list..
I determined that my Jack issue is a bad motor.( thanks YouTube) I ordered one on Amazon..
