RV.Net Open Roads Forum: Tech Issues: E7 error
 > E7 error
obiwancanoli
Napa
Posted: 09/16/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
My Dometic thermostat is showing an E7 error... noticed first when heat pump wouldn't come on... later, the a/c showed same error... can I fix this? How? WHat does it mean?
Thanks
Ranger Smith
Wherever the rig is parked
Posted: 09/16/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
A simple Google Search . . .
What is the E7 code on a Dometic thermostat? When you see this code, the system is telling you that all 120 AC power has been lost and the system cannot operate as it should. That loss of power is for all power modules connected to the system. Checking for a blown breaker is one way to fix this issue.
I guess it is easier for someone else to search for you
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX101D, Ameritron AL-80 Amp, Icom 7100, Yaesu FT-991A
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
rhochnadel
Arizona
Posted: 09/16/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Loss of 120 volt power to the A/C.
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"">
CA Traveler
The Western States
Posted: 09/16/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
X2 Makes me wonder...
Saw you also have a MKX - Just had to change the original battery as it failed on my 2017. What a nightmare and gone are the days to remove a few bolts and lift the battery out.
2014 Grand Cherokee Overland
Bob
obiwancanoli
Napa
Posted: 09/17/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
After I posted my inquiry, sir, I DID do a search... thank you for your input
 > E7 error
