RV.Net Open Roads Forum: Toy Haulers: Voltage Dump Valve Replacement
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Voltage Dump Valve Replacement
lightfoot
Cary, Illinois
Posted: 09/17/21 05:33am Link  |  Quote  |  Print  |  Notify Moderator
I am looking to replace the manual pulls for the gray and black tanks with electrically operated valves. I need to know the size of the 2 existing valves so I can order the correct size replacements.
The trailer is a 2015 Voltage 3200.
USN EN2
2012 Ford F250 SC, 6.7L TD
2015 Voltage 3200
2004 Honda GL1800
nayther
Burbank, CA
Posted: 09/17/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
black valves are all 4". I THINK the grey is 2". If you OD of ABS is about 1/4" more than "nominal" size (ie 4" ABS is 4 1/4" OD).
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
ScottG
Bothell Wa.
Posted: 09/17/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Black = 3" / grey = 1.5".
lightfoot
Cary, Illinois
Posted: 09/17/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies, but one of you has to be right and the other wrong or maybe a combination. Have either of you actually done the valve replacement on a voltage?
opnspaces
San Diego Ca
Posted: 09/17/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
The black valves are 3" and all gray are 1.5"
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Tyler0215
Iowa
Posted: 09/17/21 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Go measure yourself, then you will know.
ScottG
Bothell Wa.
Posted: 09/17/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Try to buy 2" and 4".
rjr6150
Colorado
Posted: 09/17/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
35 years Colorado Master Plumber. I can assure you the valves are 3” & 1.5”. Sad when individuals don’t know the correct answer they just throw something out there.
Randy & Kathy
2016 F350 CC SWB 6.7 Platinum with a few mods
08 F350 CC SWB Lariat 6.4 PSD
Pull Rite Superglide 18K
2013 Heartland Landmark Key Largo
lightfoot
Cary, Illinois
Posted: 09/19/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Well, I got under the trailer, removed the covering and located the 2 main dump valves. The 2 valves are the same size, that being 3" and about 18" apart. both dumping into the main 3" pipe. I also have a 1.5" pipe coming from a rear gray tank that is only used for the kitchen sink and that valve is working. RV tech will be replacing the current 3" valves with electrically operated 3" valves next week.
deltabravo
Spokane, WA
Posted: 09/19/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Ditto. LOL
Also worth noting, The valve sizes are an RV industry standard, they aren't specific to a Voltage, or different sizes on various other RV.
