RV.Net Open Roads Forum: Class A Motorhomes: Tow hall mode
 > Tow hall mode
FLHTCI
east coast
Posted: 09/17/21 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Greetings all,
I pulled the trigger on a Winnebago Itasca Sunstar 30T.
The previous owner drove it always in Tow Hall mode. Is this a wise decision??
I assume I should only use the tow mode when pulling my Jeep or my Harley trike trailer?
Thank you
2012 Winnebago Itasca Class A Sunstar 30T
2013 Jeep Sahara (JKU)
2012 Harley Davidson FLHTCUTG
2012 Ford F-250
way2roll
Wilmington NC
Posted: 09/17/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Do you mean tow/ HAUL mode? The Ford is equipped with a tow/haul mode feature that's very helpful when towing and especially helpful on descents. When in tow/haul mode you can tap the brakes on a descent and it will act similar to an engine brake allowing you to use less brakes and over heating them. In our previous MH, I found it helpful even when not towing in stop and go traffic as it changes the shift modes and helps slow you down without a lot of braking. But the tow/haul mode is designed exactly for towing.
Y-Guy
Tri-Cities, WA
Posted: 09/17/21 08:18am Link  |  Quote  |  Print  |  Notify Moderator
I usually use it when I'm towing our boat/atvs/jeep, I also use it when I'm in the mountains even if I'm not towing. I also find it helpful if I'm in traffic and want a bit more stopping power to help with the people that pull in front of me.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
NamMedevac 70
Reno
Posted: 09/17/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I always used it when towing TT in the mountains and flatlands. Maybe save a little wear and tear on brakes and transmission but supposedly increases fuel consumption. I would think same benefits for MH. Many MH I see are towing a car on carrier, dolly or as a toad or they are pulling a cargo trailer and sometimes a small TT. Cheers to
* This post was edited 09/17/21 03:15pm by NamMedevac 70 *
FLHTCI
east coast
Posted: 09/17/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Yes that is what I meant lol.
phillyg
SWFL
Posted: 09/17/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Assuming it's a Ford chassis, it's not necessary to use TH all the time. All it does is change the shift points, and it seems most effective at downshifting on deceleration. I use it to keep the RPMs in the sweet spot. If you're pulling a toad, you might use it more.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
FLHTCI
east coast
Posted: 09/17/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all.
Desert Captain
Payson
Posted: 09/17/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
TH does far more than merely adjust your shift points. Unless your coach is small and lightly loaded, towing nothing, using Tow Haul all of the time is a good way to go. On a long flat/slight downhill stretch obviously disengaging TH is fine as well. The sheer weight of most motorhomes over 24' provide more than enough load for the advantages of TH to far out weigh minimal {if any} decrease in mpg.
On occasion I have simply forgotten to engage TH. This bit of foolishness on my part is quickly exposed when I glance at my Scan Gauge on even a slight grade and note the trans fluid temps climbing 12 - 15 degrees. An "Oops' followed by reengaging TH generates an almost immediate drop in trans fluid temps back to normal... [emoticon]
Following a rig on a long mountain descent it becomes immediately apparent if they are not using TH as they are constantly on their brakes often arrive at the bottom of the grade with significantly reduced braking capability due to their overheating. The other huge benefit to TH use on descents is that you are not burning a drop of fuel regardless of rpm. TH locks the the torque converter and shuts off the flow of fuel to the engine enhancing not only control but fuel efficiency as well.
[emoticon]
Monterey, California
Posted: 09/17/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Watch your RPMs and water and transmission temps and engage if going up.
wildtoad
Blythewood, SC
Posted: 09/17/21 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
In my case I start the engine , press tow/haul. If I’m driving in very flat straight roads I’ll turn it off.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
 > Tow hall mode
