RV.Net Open Roads Forum: Truck Campers: Solar install question
 > Solar install question
StirCrazy
Kamloops, BC, Canada
Posted: 09/27/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
I put mine on over the winter. for now I did a 325 watt split cell panel, and a renogy 40 amp mppt charge controler. the best thing you can do is find the biggest panel you can put on size wise. make sure you have room for two even. I made a carboard cut out and climbed up and layed it around to see if different size panels would fit and how they would fit.
do yourself a favor and go with a 24v panel and split cell if you can. way more efficient in early moreling or lower light levels. mine wanst prewires, so I ran the wires into the fridge vent on the roof then took off to the battery compartment from there. all togeather it was about 600Cdn for the panel, controler, mounting kit, wiring kit, new battery wires from the controler and so on. I know in the US stuff is a lot cheeper so I would expect you could di it for about 300.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
deltabravo
Spokane, WA
Posted: 09/28/21 07:00am Link  |  Quote  |  Print  |  Notify Moderator
daily double wrote:
Has anybody had a solar installation on their rig recently? I'm camper shopping and wonder about the cost of aftermarket solar add-on
Lots of options.
www.amsolar.com is where I bought my solar.
I bought My Battleborn batteries and Victron DC to DC charger direct from Battleborn.
My Victron inverter was purchased from Northern Arizona Wind & Sun
Here's an overviewof the solar on my AF 811
