RV.Net Open Roads Forum: Tech Issues: Group 24 Flooded to Group 31 AGM
 > Group 24 Flooded to Group 31 AGM
ApexAZ
Gilbert, AZ
Posted: 09/17/21 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
We are going to sign for our new toy hauler tomorrow and I inquired about upgrading the batteries that come with it from the group 24 flooded to group 31 AGM and as part of their quote, they said there is labor needed to rewire them.
They said part of the $250 labor is to upgrade the wiring to a heavier gauge wire to support the bigger batteries. What I'm a bit unclear on is whether this is just the wires needed to connect them in series, or will the wires that lead to the panel also need to be upgraded?
I know these batteries have higher amp hour ratings, but at the end of the day, they are still just 12v batteries, so I would think it would just require heavier gauge wire for connecting them in series, but that's it?
Can anyone confirm that's all that would be needed and that the rest of the electrical does not need to be modified to make this change? If so, it seems like something I could easily do myself I would think?
Thanks,
Brian
countrykids
Minnesota
Posted: 09/17/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t sign until you get the correct answer on this. The dealer may be correct and we are both going to learn something or he is trying to get an extra $ 250. If that is true then you may want to walk away and not do business with him.
2004 Born Free class c
Boon Docker
Posted: 09/17/21 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Your trailer is going to draw the same amount of amperage whether you have a GR24 or a GR31. So heavier wiring is not needed.
If the $250 charge includes the upgraded AGM batteries then go for it. If it is just for heavier wiring tell them to pound sand.
Ed_Gee
Central Oregon coast
Posted: 09/17/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Fully agree with Boon Docker... nothing in the coach is changing.... you still can only use so much power no matter how big your batteries are...and your battery charger is only capable of charging at whatever its max charge rate is.... so putting in bigger batteries does NOT require any change in wiring. Your shop is trying to scam you .... or they are idiots.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
countrykids
Minnesota
Posted: 09/17/21 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
X
ApexAZ
Gilbert, AZ
Posted: 09/17/21 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
That's kind of what I was thinking, but I don't know enough about electrical to know if somehow the larger batteries would somehow output more or something. It just seemed off.
So the bigger wire gauge is probably just to run them in series. What's frustrating is that they would have to wire this anyway to put the standard group 24 batteries in, because it comes with 2.
So the $250 labor is to do the batteries and install a larger battery compartment tray on the hitch. Seems like highway robbery to me.
Really appreciate the input. I'll just do it myself.
ApexAZ
Gilbert, AZ
Posted: 09/17/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Can anyone recommend a good AGM battery, or are they all similar?
Sandia Man
Rio Rancho, NM
Posted: 09/17/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, what a rip off, first they added warranty to your OTD price, and now what amounts to a few bucks of wiring they want $250. We are from the PHX area, which dealer are you purchasing your TH at so I can tell family and friends to beware. I asked our dealer when we purchased our TH what it would cost to beef up our battery bank, he stated first battery is included, only additional expense would be actual cost of extra batteries, no fake labor or wiring charges. I just asked for giggles anyway, we put a couple of 6 volt golfcart batteries from Samsclub since we mostly boondock and they are much hardier for that type of off grid RVing. Have lots of great times in your new TH!!!
BFL13
Victoria, BC
Posted: 09/17/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
There is no wiring change needed as noted above.
The only thing is the one 24 they supply will be wasted money when you go for two 6s or two 27s later, so the saving for you should be for them to keep their single 24 and reduce your cost, and you supply your own batts, or they supply the batts you want and give you the cost of that one 24 off the price of the other batts.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Posted: 09/17/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Unlless they upgrade the converter there is no need to re-wire.
