RV.Net Open Roads Forum: Class C Motorhomes: Battery Disconnect Switch ??
 > Battery Disconnect Switch ??
kioticoachman
17821
Posted: 09/17/21 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Have an older 2001 Coachman Catalina Sport. The Battery Disconnect Switch has an in-use and store switch. It is a Interellec BDO. The in-use selection does not engage, activate, or turn on. Just replaced the DC battery today with a New battery. Same results! Hope this helps?
Any an all assistance would be appreciated. Thank you very much. KK USAF 62-66
bobndot
Posted: 09/17/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
new battery must be fully charged for things to work put a separate charger on the new battery then try .
enblethen
Moses Lake, WA
Posted: 09/17/21 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Battery connected corectly< polarity?
Did you try cycleing switch?
relay
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
kioticoachman
17821
Posted: 09/17/21 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Current battery voltage is 12.5V
kioticoachman
17821
Posted: 09/17/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
relay
Polarity is correct. Not sure on what/how you mean by cycleing switch as I have tried switching from use to store a number of times. Will check out that relay link you posted. Thanks for info sent. KK
enblethen
Moses Lake, WA
Posted: 09/18/21 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Pull switch from the wall, check for 12 volts DC
No power, check for blown fuse.
Cycling is operating from one function to the other and back. Like you did.
enblethen
Moses Lake, WA
Posted: 09/18/21 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Another way to test is to put a volt meter, set to 20 volt DC scale, between the two small terminals, have helper hold switch in one position. Meter should read voltage either positive 12 volts DC or negative, then have helper hold in other position. Meter should read 12 volts DC with opposite polarity.
bobndot
Posted: 09/18/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the connections on the relay solenoid are clean. The solenoids are not expensive, i would buy a new one and try it. Its a common enough fix in these systems, if that doesn't help, keep it as a spare. Its a good part to have on hand.
kioticoachman
17821
Posted: 09/18/21 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Checked all the fuses that power the coach and all are good.
LittleBill
Scranton, PA USA
Posted: 09/18/21 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
if this is the unit im thinking of, it has a fuse itself on the solenoid itself, has that been checked and or does the led glow on the disconnect switch?
