RV.Net Open Roads Forum: Tow Vehicles: New Truck question(s)
Search only in Tow Vehicles
 > New Truck question(s)
Page of 5
marpel
notapplicable
Posted: 09/17/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Good day,
As my current truck has reached it's retirement, I am beginning to look at a new vehicle.
We have a relatively small trailer (22' and about 5k lbs loaded) and have been towing it with a GMC Sierra, 6.2L, 6spd, 373. On short trips it has been a fine combo.
However, since the birth of a grand-daughter in Denver Co, we have spent every vacation driving back/forth from BC, Canada, via various interstates, with speed limits at 60/70/80, depending on location. And anticipate this will continue for a good number more years.
Currently, pulling at 63-64-ish, I put it in 5th, as in 6th it will constantly downshift at even the slightest incline/overpass. Much (like 80%) of the route is like this. Of course, up hills/mountains is understandably different.
I am considering going up in size to a 2500 or 3500 with the 6.6L gas, not diesel (may upgrade trailer in future), and am wondering if this would allow pulling in overdrive, rather than in 5th, during those long straight stretches. I am also considering the Ford 7.3 but think it may be a bit overkill for my needs, although it remains an option.
Any other thoughts would also be welcome.
Many thanks,
Marv
KD4UPL
Swoope, VA
Posted: 09/17/21 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
5th gear is also an overdrive in that transmission. So you are technically towing in overdrive, just not the highest one.
You're current engine is rated 420 Hp and 460 lb/ft. The 6.6L is rated 401 HP and 464 lb/ft. So, you're not gaining anything but the power peaks are at a lower RPM which is nice.
wing_zealot
East of the Mississippi
Posted: 09/17/21 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
You need something with the 10 speed transmission.
JIMNLIN
Oklahoma
Posted: 09/17/21 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
The 6.6 GM or 7.3 Ford gassers will still downshift in the same situation. Maybe even more so....less hp same torque and a heavier gross weight truck. Use a lower gear where the tranny won't downshift all the time.
Now if your going to upgrade to a heavier trailer then a 3/4 tom makes sense.
marpel
notapplicable
Posted: 09/17/21 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
KD4UPL,
Thanks for the reply.
Sorry, I should have been a bit more clear in the first instance. My current truck is ten years old and is rated at 403 hp and 417 lb/ft. Which is why I was curious if the added lb/ft in the 6.6L would resolve the question I posed, or if it would benefit from a higher hp, more than the increase in torque.
As mentioned, my truck pulls fine for most applications, it's just when we are out on the interstates and extremely long distances that I wish for a wee bit better performance.
Marv
marpel
notapplicable
Posted: 09/17/21 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
wing zealot and JIMNLIN,
I guess you posted while I was replying to KD4UPL.
I must really not understand trucks and towing. I often read comments about guys towing a zillion pound trailer down the highway at 65+ mph, with little effort. I just presumed the bigger HD truck/motor they describe would pull a small trailer like mine with ease, even at interstate speed.
I'll have to do some more learning.
Marv
APT
SE Michigan
Posted: 09/17/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Why do you care about towing in 6th gear? Those gas engines will be happiest towing in 5th. Pick you speed, 62mpg or 78mph, but 5th gear for the GM engines. One benefit of the 2500 is the larger fuel tank (and range).
2017 Subaru Outback 3.6R
theoldwizard1
SE MI
Posted: 09/17/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
3/4 ton, bigger engine, more years in the transmission, you will love it !
wowens79
Georgia
Posted: 09/17/21 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
While the Peak ho and torque numbers are similar between your 6.2 and the motors in the hd trucks, if you look at the torque curve, you get lots more torque at lower rpms.
I wa awaiting for the 2020 Chevy hd to come out, but I think Chevy messed up staying with a 6 spd. In all the comparisons, the Ford 7.3 handles loads much better. But if you stick with a similar size trailer, the 7.3 may not be needed, but it’s priced similar to the others.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Posted: 09/18/21 06:20am Link  |  Quote  |  Print  |  Notify Moderator
And then, apples to apples, it will pull in a lower gear as well. Probably 7th 8th or 6th.
OP don’t fixate on towing in top gear. And fwiw your truck doesn’t give up much at all to any new 3/4 ton gasser for towing power.
2017 Heartland Torque T29
Page of 5
