RV.Net Open Roads Forum: Can I Use Gear Oil On Dual Cam
 > Can I Use Gear Oil On Dual Cam
Arn
Ottawa Valley, Ontario, Canada
Posted: 09/17/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Can I use an 80W90 gear oil to lubricate the trunnion pivot points & cams on Reese Dual Cam? Reese says grease on cams is okay if close to 1200lbs hitch weight. I'm about 1,150lbs. Thanks.
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
Bobbo
Wherever I park
Posted: 09/17/21 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Oil is too thin and will run off. Use grease.
Bobbo and Lin
dodge guy
Bartlett IL
Posted: 09/17/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
I used regular wheel bearing grease on the ball and trunnions. I used a small dab of white lithium on the cams. just enough to stop the noise of the bars passing over the cams. My tongue weight was 1200lbs/
BTW, when the time comes you can flip/flop the cams side to side so you can then use the unused bottom side as the new cam surface. for me that was about 10 years which was about 20k miles.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Arn
Posted: 09/18/21 05:00am Link  |  Quote  |  Print  |  Notify Moderator
I currently use wheel bearing grease on ball & trunnions as well. I tried Reese's recommendation of Vaseline on the cams without much success. Sometimes when turning the friction is so great that it sounds like something is breaking & the "pops" are so violent they seem to shake the trailer. Next up, white lithium grease. Thanks.
JRscooby
Indepmo
Posted: 09/18/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I don't know why anybody would even think of using anything that smells as rear-end grease if anything else would work.
noteven
Turtle Island
Posted: 09/18/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned gear lube is very pungent...
A plastic squeeze tube of the waterproofest grease you can find would be a reasonable choice.
Monterey, California
Posted: 09/18/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Follow Reese’s guidelines IMO. I’d use grease.
Bobbo
Wherever I park
Posted: 09/18/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Whereas, Vaseline on the cam surfaces works very well for me. For several trips before needing to be reapplied.
thomasmnile
Lake Mary, FL
Posted: 09/18/21 10:27am Link  |  Quote  |  Print  |  Notify Moderator
I used Vaseline on my Straight Line dual cam for the entirety of my ownership as Reese suggested. Zero problems. The bonus was an easy removal and cleanup with shop rags after every trip.
Regarding snapping, popping and clunking. Only sounds I ever heard like that was when making turns. No effect on the trailer or the hitch.
