RV.Net Open Roads Forum: General RVing Issues: DOT CODE WITH LETTERS
 > DOT CODE WITH LETTERS
rx2tee
Mojave Desert
Posted: 09/18/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I just looked at a friend's trailer and the DOT code was R2NN.
I AM only familiar with the numeral week/year code.
2002 4x4 f-250 LB 7.3 Powerstroke
6-spd manual 3.73 axle
Gemtop
Rhinoliner
Pullrite hch, Prodigy Bk. Ctl.
Jayco 25RKS
Randy & Colleen
enblethen
Moses Lake, WA
Posted: 09/18/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I believe that is manufacturer and plant number not the dayte code.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Gary45
Oshawa, Ontario, Canada
Posted: 09/18/21 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Look on the other side of the tire
SDcampowneroperator
South Dakota
Posted: 09/18/21 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
DOT date code is # s like 4912 , meaning 4 th week Sep. 2012.
Prior to. 2000 it would have been 3 #, week mo last digit. of year.
A bias ply spare on my boat trailer made in '86 dated to '1985.or even to 1975.when date codes began. found and changed that last year.
Since that tire was a E 78/ 14 bias ply with code of 466 , all info points to it being a 1976 maybe '86 tire. The E 78/14 sizing says 1970s. By the mid '80s sizing metric proportions and percentage were dominant.
A new trailer doas not mean new tires. They could be years old
fj12ryder
Platte City, MO
Posted: 09/18/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I believe a date code of 4912 would mean the tire was made the 49th week of 2012.
Howard and Peggy
"Don't Panic"
bucky
Raleigh metro
Posted: 09/19/21 03:59am Link  |  Quote  |  Print  |  Notify Moderator
Yes, 4th week would be 0412.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
CapriRacer
Somewhere in the US
Posted: 09/19/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
The DOT code is a 10 to 13 digit "number" on the sidewall of every tire that hits the street in the US.
I go into more detail here: http://barrystiretech.com/dotcoding.html
The complete DOT code only needs to be on one side, but a partial code is required for the other side - and that one will be 6 to 9 digits long.
Tires that do not hit the street are NOT required to have a DOT code, but many do, and they are NOT required to follow the DOT coding format. Sometimes the tire manufacturer will have its own coding system - as did even street tires prior to the early 1970's.
CapriRacer
Visit my web site: www.BarrysTireTech.com
bobsallyh
Livingston, TX.
Posted: 09/19/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Frequently if the tire has the date code only on one side of the tire , tire jockeys and tire shops will turn that tire to the inside of the wheel.
deltabravo
Spokane, WA
Posted: 09/21/21 07:04am Link  |  Quote  |  Print  |  Notify Moderator
DATE code and DOT code are two different numbers.
Note your original post says "DOT Code", which is exactly what the code you found is. It's not the DATE code.
