RV.Net Open Roads Forum: Replace water pump in a 300 cummins c series
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Replace water pump in a 300 cummins c series
Greggy
Baltimore
Posted: 09/19/21 12:13am Link  |  Quote  |  Print  |  Notify Moderator
I know it's probably a dumb question but do I need to drain out the coolant before I undo the water pump?
I got to do this on the street and not make a mess.
haste maker
alabama
Posted: 09/19/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
If your luck is like mine, there is going to be mess, so I would drain the coolant into a pan first.
Retried Teamster
2007 Allergo
wolfe10
Posted: 09/19/21 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Simple answer-- YES.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
FordMastertech
Burlington CT
Posted: 09/19/21 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you need to ask this question you should find someone else replace the water pump
Tim & Donna ">
04 Prowler 830Y lots of mods 5200 lbs Axles 16 inch LT E tires
00 Ford Excursion Limited 4x4 7.3 PSD Pullrite Prodigy Autometer Gauges Magnaflow Exhaust DP Tuner Chip Terminator Big Oil ">
Ivylog
Blairsville, GA and WPB, FL.
Posted: 09/20/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
You were correct…dumb question!
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
