RV.Net Open Roads Forum: Fifth-Wheels: Remote duel fuel 2500 watt generator?
 > Remote duel fuel 2500 watt generator?
Duke-44
Wyoming Rockies
Posted: 09/19/21 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Are there any lightweight quiet generators like this out there. I am not sure what I am looking for. I have a small Honda 1500 watt now just wondering.
I actually would like something I could install in a 30 ft fiver garage.
MFL
Midwest
Posted: 09/19/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Champion makes a 3500 inverter gen that meets most requirements, maybe not so lt wt, but has wheels.
Jerry
rlw999
Washington State
Posted: 09/19/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
You can find propane conversion kits for many of the Honda generators online, so if you're happy with the one you have, you may be able to convert it to dual-fuel.
agesilaus
North Florida
Posted: 09/19/21 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
You will burn a LOT of propane in a generator. Go thru a 20 lb bottle a day. Propane has much lower energy density compared to gasoline.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
NRALIFR
Truck Camping Out West
Posted: 09/19/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
For occasional and short term usage, LP is fine for a generator. The convenience and reliability make it worthwhile. If you need generator power for long term use (like air conditioning) you’d be better off sticking with gasoline. You didn’t say what your needs are, but those are the two ends of the spectrum.
I’ve got both ends covered with my built-in LP powered Generac, and my portable gasoline powered Yamaha 1000. The Generac occasionally gets used, typically for just 10-30 minutes. At 20 years old it only has about 125 hours on it. The Yamaha doesn’t have an hour meter on it, but I’d bet it has hundreds, maybe even 1000’s of hours on it.
I always appreciate being able to start the Generac from inside by just pushing a button though.
[emoticon][emoticon]
* This post was edited 09/20/21 02:14am by NRALIFR *
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
ssthrd
Vancouver Island
Posted: 09/19/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
I use a Champion 4500/3500 Inverter generator that works for me. Weighs about 100 lbs with full gas tank, so is a bit on the heavy side.
2014 Keystone Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Andersen
DeeBee, JayBee, and Jed the Black Lab
valhalla360
No paticular place.
Posted: 09/20/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Use case is critical.
- If you are just charging the batteries, making some coffee or watching some TV, your little 1500w is a great option.
- Once you want to run the air/con, something in the 3000w or better is my recommendation.
Yes, you can dink around and make a smaller generator work but it's hit and miss. We have a 2400w Yamaha and there are times, it struggles to get the air/con to start up.
The other issue with propane is the engines generally put out less power when on propane. So a 2400w generator may only be good for 2000w on propane.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
2112
Posted: 09/20/21 04:38am Link  |  Quote  |  Print  |  Notify Moderator
I'm not finding anything with a remote in that size. This is 2500W Peak on propane but only 1665 running watts.
2013 KZ Durango 2857
laknox
Arizona
Posted: 09/20/21 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Generally, you won't find remote-start gennys < 3k watts. Personally, I can't think of a single one < 3k with remote start.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
agesilaus
North Florida
Posted: 09/20/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
There is soft start which has a good rep and supposedly lets a 2.3K run the a/c. But the dual fuel plus remote start combo does not exist so far as I know in that size range.
