RV.Net Open Roads Forum: Installing generator and propane tank on rear rack of fiver?
 > Installing generator and propane tank on rear rack of fiver?
Duke-44
Wyoming Rockies
Posted: 09/19/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I already have a rear rack on my fiver and my power inlet is there, too. Is there any problem with installing the propane generator and propane tanks there?
stickdog
Somewhere, USA
Posted: 09/19/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Only if someone rearends you.
I csrry my 2 3000 generators
2 5gal gas cans and 2 5 gal diesel cans.
I figure I'm far enough a hhead of the boom.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
theoldwizard1
SE MI
Posted: 09/19/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Get a good, experienced welder to build that rack.
It will lighten the pin weight.
laknox
Arizona
Posted: 09/20/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
If you =do= do this, install in a "gen box" to cover everything up and give it at least a little disguise. One YT couple had a Champion 3k stolen right off their cargo rack in downtown Denver rush hour traffic. Got in a hurry and forgot to put the cable lock on it; scumbags just cut the ratchet straps.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
valhalla360
No paticular place.
Posted: 09/20/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
As long as it's relatively light generator and you beef up the rack (welding directly to the frame), should be fine.
Yes it will impact the pin weight but 5ers start with a much higher percentage on the pin compared to bumper pull and with the wheels further back, each pound in the rear takes less weight off the pin.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Monterey, California
Posted: 09/20/21 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Consider extra lights for the rack.
Allworth
Orlando, FL
Posted: 09/20/21 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Propane on the rear rack may not be DOT legal!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
memtb
Wyoming
Posted: 09/23/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
I don’t see an issue with fabricating a rack......assuming that you have sufficient frame integrity and the weight will not adversely effect your pin/tongue weight.
All of that said......if I have a choice, I would never go propane. Been there - done that ! As compared to gasoline .....propane is very inefficient! You will use much more propane to accomplish the same job. PLUS - gasoline is quite accessible and is a quick/easy fill.....propane - not so much! JMO! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
