RV.Net Open Roads Forum: Labels for wire bundle that won't fall off
 > Labels for wire bundle that won't fall off
bighatnohorse
Gig Harbor - Cave Creek
Posted: 09/20/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I need to label some split-wire loom cables.
Some of the cable is in the engine compartment and some cable is beneath the (jeep) front bumper area - somewhat exposed to weather.
At present, I've wrapped the split-loom with black electrical tape.
Then, using a household file label printer, applied the label over the black electrical tape, then wrapped that in clear strapping tape.
It probably won't last more than a few years.
I need something more permanent - any ideas?
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
WNYBob
Tonawanda, NY
Posted: 09/20/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I use a Brother P-Touch Cube Smartphone Label Make. It uses a smartphone app to create labels that are water proof.
and zip ties that have a place for labels. Monoprice Marker Cable Tie 4 inch
Both available on Amazon.
Posted: 09/20/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
That’s about as good an idea as I could come up with.
One better may be to get some clear bra type film. Stick the labels to that and then wrap around loom. That will last virtually indefinitely.
I did this on all the “original” under hood labels on the truck we’re restoring. Labels were good but starting to weather.
2017 Heartland Torque T29
rk911
DuPage County
Posted: 09/20/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
how about something like this. use a permanent marker on the plastic tag, wrap that in a a couple of layers of clear packing tape and then attach to the loom with a length of insulated wire.
https://www.nelcoproducts.com/store/cable-tie-identification-tags.html
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
DrewE
Vermont
Posted: 09/20/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Some of these might work decently well.
The Dymo Rhino system looks really nice, but is not at all inexpensive for only a single project or two. Maybe you could find someone who has one or rent one somewhere. It's basically a handheld label maker that spits out heat-shrink tubing with the labels, and you can then shrink the tube and label around the wire. Other companies make similar tools, too (e.g. Brother).
frankwp
Calgary, AB, Canada
Posted: 09/20/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Brady makes an extensive line of industrial wire labels for just about any imaginable environment. If the wire will survive it, chances are the labels will too.
Brother also makes some very good labelers & labels, but Brady has them beat for hard usage labels.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 09/20/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
BP22 by BRADY
Using the NYLON marker cartridge.
Beware of BRADY because the quiescent current draw will thoroughly drain 8 batteries in 2 weeks. I recommend a wall wort and forget the batteries. The memory is not volatile.
GOOGLE for the protocol to minimize unused excess label length. These cartridges are anything but cheap.
enblethen
Moses Lake, WA
Posted: 09/20/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Flag cable ties used with a Sharpie
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CA Traveler
The Western States
Posted: 09/20/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
White Scotch 35 tape and permanent sharpie. No better tape that I'm aware of especially the black Super 88.
2014 Grand Cherokee Overland
Bob
wing_zealot
East of the Mississippi
Posted: 09/21/21 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Aren't they color coded? write it down? make schematic wiring diagram.
