RV.Net Open Roads Forum: What's in your tool kit? What about other must-haves?
 > What's in your tool kit? What about other must-haves?
ApexAZ
Gilbert, AZ
Posted: 09/20/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Our new toyhauler is being delivered tomorrow!
I've sorted out capacity, weight, hitches and all that, but what about things that go on the inside of the RV?
So far we have purchased:
Sewage hose kit
Kitchen stuff
Outdoor griddle
Bedding stuff
Cleaning stuff
A basic tool kit, such as hammer, screwdrivers, allen wrenches, a socket set, leveling bubble, tape measurer, etc.
Air compressor is still on our list of things to buy
Fix-a-flat and tire change kit - I think it comes with a tool to lower/release the spare tire, but I am not sure if it will fit the actual wheel lugs. Also, do we need some sort of jack in the event we need to change a tire, or will the one that came with my truck work?
Are there any other tools or essential items we need to get that we aren't thinking of? I'm assuming so. Suggestions?
valhalla360
No paticular place.
Posted: 09/20/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Food, clothes...
Toys for the garage?
I would lean toward taking a few short trips and see if you miss something. It's easy to overload packing for every possible issue.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
ApexAZ
Gilbert, AZ
Posted: 09/20/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Food, clothes...
Yes, after subtracting the weight of our General, fuel and water, we have about 1100 lbs to spare. Maybe closer to 1k after we replace the mattress.
We bought all plastic dishes, a cheap and lightweight pots and pan set. Minimal tools.
I expect to do several trips to the scales as we settle in.
Certain things, like the griddle, ice chest, 20 lb propane tank, luggage, etc, we can carry in the bed of the truck.
RedRollingRoadblock
Oregon
Posted: 09/20/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Multi-meter and have the basic knowledge on how to use it.
ApexAZ
Gilbert, AZ
Posted: 09/20/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
This is something I hadn't thought of, thanks!
Do you think we should get a traditional one with leads, or a clamping type?
thomasmnile
Lake Mary, FL
Posted: 09/20/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Torx bit screwdrivers in addition to slotted and Phillips. Unless the RV industry has changed Torx screws are their favorite fastener after staples.
Maybe a suitably sized bottle jack for tire changes if you don't have one.
Dick_B
Palos Heights, IL USA
Posted: 09/20/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
GPS.
Tire pressure gauge. I like the digital ones.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
OkieGene
oklahoma city
Posted: 09/20/21 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, absolutely Yes. You can buy a single unit that has both the clamp on as well as leads.
Allworth
Orlando, FL
Posted: 09/20/21 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
My Titanium (a Canadian Manufacturer) does NOT use Torx. The fastener of choice id "Roberts" #1 and #2. A square recess in the head.
Roberts drivers and power bits in both sizes are available at Northern Tool.
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
OkieGene
oklahoma city
Posted: 09/20/21 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
I'd look things over carefully, you might have some fasteners that use the Square Bits, the Robertson type.
