RV.Net Open Roads Forum: Fifth-Wheels: hydro or electric leveling
 > hydro or electric leveling
SUMRX4
VA
Posted: 09/20/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
So wife and I just returned from the show in Hershey and are no closer to knowing the "one" than before we left. [emoticon]
If anything I now have more questions.
Those of you that have possibly owned a unit with both hydraulic and electric leveling jacks, which do you prefer and why? I realize hydro is faster but I'm not concerned with speed. If more concerned with ease of use, reliability, maintenance (if any) and bypass ability should something fail.
n0arp
FT
Posted: 09/20/21 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
We've had both, and will only ever have hydraulic going forward.
Much faster, more reliable, more convenient, etc.
We had issues with gears (sheared one) and motors (burned one out) on our electric jacks. On our hydraulic system, the only issue we ever had was a leaking seal that still allowed the system to work until it was replaced. I think you can get auto-leveling with electric now, but auto-leveling with hydraulic is all that was available (I think) when we purchased, and it's a feature I wouldn't want to go without.
You can easily lift the whole trailer with the hydraulics - not something I recommend doing - but it's gotten us out of a pinch on more than one occasion. Once for an emergency suspension repair, and once for getting us unstuck. I don't believe the electric jacks are capable of that.
* This post was edited 09/20/21 02:29pm by n0arp *
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
memtb
Wyoming
Posted: 09/20/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hydraulic......Bigfoot to be specific! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
fj12ryder
Platte City, MO
Posted: 09/20/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
We've only had the hydraulic auto-level system, but IMO it would be better than electric. With hydraulic, there is one pump and six/four cylinders. Electric would have six/four electric motors and accompanying gears. I prefer the KISS principle.
Howard and Peggy
"Don't Panic"
Second Chance
Wherever...
Posted: 09/20/21 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
We've had both. I've experienced a leaky manifold (replaced it myself with part supplied under warranty) with the LCI hydraulic system and had to add CAT anti-stiction fluid to stop the annoying popping sounds. On the other hand, it will lift the trailer off the ground one side at a time to change a tire.
The electric system was much slower and I didn't trust it to lift one side of the trailer (not as robust). A couple of pros for the electric systems - especially ones with the new hall effect motors - is that they are more easily user-repaired.
Bottom line: I don't know that I'd let hydraulic vs. electric make the decision for me. I would be more concerned about a floorplan that would work for us.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
jdc1
Rescue, Ca
Posted: 09/20/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Electric has one motor to fail. Hydro has a motor, the hydraulic pump, rams, and hoses that can fail. You can decide from there.
Second Chance
Wherever...
Posted: 09/20/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
The new electric systems have a motor on each strut.
Rob
Bumpyroad
Virginia
Posted: 09/20/21 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I had issues with my hydraulic levelers.
bumpy
griffy00
Grants Pass, OR
Posted: 09/20/21 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
We replaced our electric levelers with the BigFoot hydraulic levelers. One major drawback: There is NO manual override should one of the BigFoot hydraulic jacks fail. Recently we had one of the front jacks fail to retract and we could not move the trailer in that condition. I called the BigFoot 24 hour tech line and they diagnosed a pump failure. To raise the jack for travel we had to bleed 64 ounces of ATF fluid (what a mess!) and obtain a floor jack to raise the failed jack. I understand that there are some hydraulic jack systems that do have a manual override.
'05 Ford F350 Supercab V10 SRW 430 Rearend
33.5' '05 Discover America CKQG LS NuWa Hitchhiker
Reese Signature Series 18K Hitch
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/20/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
We're on our third unit with the Lippert Level-Up Hydraulic system and combined we've covered 100K miles with very little issue. Traveled to the Canadian Maritime with Friends and their brand new Jayco Pinnacle and they had nothing but problems, including one front landing gear ripping loose from the frame. They now have a unit with the Level-Up and no problems.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
