RV.Net Open Roads Forum: Class A Motorhomes: Power Mirrors Don’t Work!
 > Power Mirrors Don’t Work!
MrWilsonSL
Ardmore OK
Posted: 09/20/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Hello! I just acquired a 2006 Gulf Stream Sun Voyager model 8388 on a Workhorse chassis with a 8.1 vortec. The power mirrors don’t move and appear to have no power to the switch. I’ve checked all fuses in the engine compartment and under the dash and found no blown fuses. Just thought I would ask before I dig even deeper in case someone has run into the same issue and can advise me on a fix. TIA!
Posted: 09/20/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Wish I could help but when I blew the fuse on my Workhorse I never did find it. And I checked every fuse I could find.
I finally put in an alternative power feed to the switch. Took it off a handy "AUX" circuit (One that was live with the key in the ACCESSORY position) and ran it through a marker light (The old fashion incandescent type) so that if anything went "Strange" the light would come on.. It never came on.
rgatijnet1
Posted: 09/20/21 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
ON my WH chassis there is a small fuse panel under the dash left side that is difficult to find and check. It is put on a holder that will allow you to reach up and slide it off to change a fuse. other than that you almost have to stand on your head to access it.
enblethen
Moses Lake, WA
Posted: 09/20/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
My mirror fuse is in the battery control center
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
zigzagrv
Nazareth, PA
Posted: 09/21/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Had an intermittent problem with my mirrors also. Turned out to be the aux power solenoid in the electric bay. Can be had at almost any auto parts store.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
MrWilsonSL
Ardmore OK
Posted: 09/21/21 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Do you recall which fuse it was or the amp rating? The diagram inside the cover doesn’t mention mirrors as I recall.
enblethen
Moses Lake, WA
Posted: 09/21/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Fuse F-9
It is on with the power window.
enblethen
Moses Lake, WA
Posted: 09/21/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
My mirrors are powered via the module in the driver's door. I had to replace the wires through the hinge portion. If yours has this module and the window works, there is problems in the module.
