RV.Net Open Roads Forum: Tech Issues: DC Conversion and Amp Hours for CPAP
 > DC Conversion and Amp Hours for CPAP
ktmrfs
Portland, Oregon
Posted: 09/21/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Bumpyroad wrote:
in addition to shutting off/down the humidifier, don't use a heated hose. since this is a bipap not a cpap I "assume" it uses more electricity ?????????
bumpy
also, most/all of the newer CPAP/BiPAP machines have internet connection as well. I turn mine off when using it in the trailer. Every little bit of power reduction helps.
And for the heated hose, Resmed makes a insulated sleeve for the hose. I have one on mine. if you want/need to use the heated hose it will reduce the power draw.
another option for the water tray is to fill it with warm water before sleeping. Even w/o the heater on it will offer some humidification and warm water helps for at least part of the night.
I can get 3 nights out of my portable battery pack if heater is off, hose heat is off, wif is off. If the water heater is on I can usually get one night, on cold days, not even one night.
Big clue on what draws power!
2011 Keystone Outback 295RE
Posted: 09/22/21 05:42am Link  |  Quote  |  Print  |  Notify Moderator
360 watt hours at 12 volt is 30 amp hours.
The CPAP likely does not use all that.. but (Due to conversion loss in the power converter/brick/wall wart) but that's figure 30 amp horus.
NOTE there are other loads on the battery 24x7
