RV.Net Open Roads Forum: Tow Vehicles: Door Switch?
Search only in Tow Vehicles
 > Door Switch?
oldcat1
CA
Posted: 09/22/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2013 Sierra 2500HD, 6.0 gas. Normally when I turn off the engine and open driver's door the radio turns off. Now it stays on and I have to turn it on and off manually. There must be other things that the door switch also turns off because if the truck sits for a week or so the battery (which is fairly new) drains down. Does this sound like the door switch, or is there some sort of relay that could be sticking? Thanks in advance for any thoughts on the matter.
Posted: 09/22/21 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Do the dome lights shut off like they should?
if so then less likely the door switch.
good luck diagnosing. I'd try chebbie truck forums for a greater chance of an internet solution.
2017 Heartland Torque T29
Fisherman
Angus, Ontario, Canada
Posted: 09/22/21 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
That switch also turns off the interior lights if it's in the door open mode. Are you sure that maybe you may have adjusted the turn off time. I know on mine, the radio off, interior lights off can be adjusted from 0 to about 2 minutes.
Turtle n Peeps
California
Posted: 09/22/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Could be a few things but I think at the top of the list a BCM.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
oldcat1
CA
Posted: 09/23/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Fisherman - how do you adjust the time? Turtle n Peeps - what is a BCM? Thanks all.
2013 GMC Sierra 2500HD 6.0
2014 Surveyor Sport 220RBS
Thunderbolt
North Branch, Mn USA
Posted: 09/23/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
My wife's 2019 Equinox did that and the dealer had to reflash the computer. Hasn't done it since then.
Bryan
2003 2500HD Ext. cab short box
6.0 liter 4.10 gears, Nelson performance PCM 293,000 miles
98 K1500 4x4 heavy duty 1/2 ton (Sold)
6,600lb GVWR 5,280lbs on the scale empty
14 bolt rear diff. 3:73 , Tranny and oil coolers
380,000 miles.
Roger10378
Goodrich, MI.
Posted: 09/24/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
"Body Control Module" A number of settings are available usually from the dash or buttons on the radio. Every vehicle is different so you will need to check your manual to find the correct way for yours.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Turtle n Peeps
California
Posted: 09/24/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
A BCM or Body Control Module is a computer that controls the switches and relays and that kind of stuff in your truck. Weird things can happen when these go bad. Check the door switch out and if that checks out ok then the BCM would be where I would go.
Good luck.
Fisherman
Posted: 09/24/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Like one of the others said, I can adjust mine with "setting" function on the radio display. yours may a bit different.
oldcat1
CA
Posted: 09/24/21 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your help. I have found that pulling and then replacing the fuse to the radio will "reset" things for a day or two then the problem re-occurs. I have an appointment with the dealer next week. I'll let you know how it shakes out. I'm an old school kind of guy and when it comes to computer controlled trucks I'm way out of my league. Thanks again to all. Safe travels.
 > Door Switch?
