RV.Net Open Roads Forum: Tech Issues: Progressive Dynamics Wizard Pendant
 > Progressive Dynamics Wizard Pendant
time2roll
Posted: 09/24/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
The PD 4hr timer is when you trigger boost with the CW, otherwise it does boost by itself if needed for as long as needed. Not sure what happens if the batts get near full before the 4 hrs is up when using the CW. From previous threads on this ISTR it thinks 97% SOC is "full" and it drops to "Normal". This showed up with fisherguy's graphs.
This sounds perfect for LFP. Too bad PD brought out the "lithium" models that run the voltage too high for too long.
675w Solar pictures back up
BFL13
Victoria, BC
Posted: 09/24/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Not sure the way PD "thinks" works with the internal resistance difference of an LFP or if that has anything to do with it.
Years ago, Hurricaner tried to correct me on how the battery limits amps, not the converter (except by its current high limit), and eventually I got that, but no idea how that works with LFPs and their version of "natural acceptance rates".
I have a notion this might affect the timing for when the PD would drop to "Normal", but not a clue what really happens.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
1L243
Oregon
Posted: 09/24/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I hit float mode this morning! It only took 3 days!!!
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
