RV.Net Open Roads Forum: Class A Motorhomes: V10 misfire codes
 > V10 misfire codes
Paulson
North Dakota
Posted: 09/23/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
We recently purchased a 2016 Fleetwood bounder with a Triton V10. On the way home on a 20 minute drive, the check engine light started flashing. Codes were P0300, P0302, and P0306. Since then on various test drives, it has popped all of the even numbered misfire codes 02 thru 10. It has never popped an odd numbered misfire code. Found out about a TSB, so took it to the Ford dealership to have the PCM software upgraded. However they informed me I already have the upgrade. We have replaced all 10 spark plugs and coils. I have checked the PCV valve hose for leaks. I have replaced the MAF. The check engine light will typically flash after having been under load, and then I back off on the Accelerator So after going up a hill, it will not flash until I take my foot off the gas, and then it will flash going down the hill. I am stumped, especially considering it only pops even numbered misfire codes. Any input would be appreciated!
theoldwizard1
SE MI
Posted: 09/23/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
You need a code reader that can access "live data". Shooting the parts cannon gets expensive quick.
First thing to look for (besides the misfire) is short and long term fuel trim. I'll bet he side still misfiring has a large positive long term trim. This indicates an air leak. If only on one cylinder it could be a bad injector.
Stop shooting from the hip !
path1
Varies with weather
Posted: 09/23/21 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have a little brother a 5.4 I had problems with mine throwing codes after chasing down all the stuff and getting injectors cleaned excetera excetera neighbor asked when last time I cleaned throttle body, found something on YouTube followed it and fixed the problem. Also I checked all electri connectors up near the throttle body maybe there's something to do with that also not sure
theoldwizard1
SE MI
Posted: 09/23/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Stop shooting in the dark !
Check fuel trims !
* This post was edited 09/24/21 06:11am by theoldwizard1 *
enblethen
Moses Lake, WA
Posted: 09/23/21 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
P0302 and P0306 are cylinder 2 and 6. Probably coil packs
P0300 is random miss fire. Commonly goes away when coil packs are replaced.
What brand of coil packs did you install? Many are not worth much inclding factory ones from Ford.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jwoods61us
INDY
Posted: 09/24/21 03:22am Link  |  Quote  |  Print  |  Notify Moderator
Intake air leak on the even numbered side.
John, Lorie, Franklin, Sammi, Tina
2009 Dodge Ram 2500 6.7l Cummins G56
2020 Rockwood Ultra Lite 2912BS
theoldwizard1
SE MI
Posted: 09/24/21 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I would agree with stick with OEM (Motorcraft), but OP says they have been replaced.
enblethen
Moses Lake, WA
Posted: 09/24/21 07:12am Link  |  Quote  |  Print  |  Notify Moderator
I would not use OEM coil packs!
zigzagrv
Nazareth, PA
Posted: 09/24/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
How is the chassis battery/connections? When my battery started going south, I would get random multiple misfire codes for a short time after startup. New battery solved that.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
Dale.Traveling
Newport News, VA
Posted: 09/27/21 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Do a vacuum leak check by spraying around the intake manifold and throttle body with carb cleaner. If you have a leak it will suck in the cleaner which will change the idle slightly.
If you can find a leak and the fuel trims are wacky then swap O2 sensors and see if your P codes change to the other cylinder back.
2006 Hurricane 31D built on a 2006 Ford F53
 > V10 misfire codes
