RV.Net Open Roads Forum: Class A Motorhomes: Tires - The 10 Year Rule
 > Tires - The 10 Year Rule
KendallP
Probably the office
Posted: 09/23/21 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hey gang,
Regarding big, DP tires...
I know most adhere to this rule and some prefer to replace tires within 7 years or so of date code. Others replace the steers every 5 and the drives every 10. Others still will have them all removed and the interiors inspected before giving up on them. Etc, etc...
I'm inclined to err on the side of caution, myself, but I'm curious to hear your thoughts. And to see if anything has changed in the last 5 years since this thread.
So given...
6 - Toyo M-154 265/75R22.5 tires with 10,000 miles
Installed March of '13, but approaching 10 years of date code
Babied and covered most of their lives, in beautiful (where visible) condition with no checks
Entire lives in Santa Cruz with a very mild climate. Last couple of years undriven and parked without the jacks down and uncovered with driver's side facing south (the sun... and Central California coastal fog)
On a Freightliner/Cat chassis running fairly close to GVWR / tire max
Replacement cost - $3,100
What would you do?
EDIT: Here's a good read posted by dougrainer 5 years ago. The study indicates 6 years is the maximum for safety. Though it appears to be general tire specific. No mention of commercial, one way or the other.
http://www.ntsb.gov/news/events/Documents/2014_Tire_Safety_SYM_Panel_4b_Kane.pdf
Also... some seem to indicate that commercial truck tires are more robust than RV tires, despite the size. I can say this... the Toyos are spec-ed at 99 lbs vs 90 for the OEM Michelins. All that said... they also undergo more severe punishment.
* This post was last edited 09/24/21 04:38pm by KendallP *   View edit history
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
toedtoes
California
Posted: 09/23/21 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
I would replace them. $3100 sounds like a lot, but when you figure out how much reparing all the damage done by an old tire blowing, it's cheap.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Posted: 09/23/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'm told that in some states tires over 8 years are considered hazardous.
(NOTE I have made no effort to verify that. I replaced the tires shortly after being told that for other reasons. (They needed it) but that is what I was told.
I've seen both 5 and 7 as the recommended replacent intervial
Just now the motor home is in a bone yard (Long story. but not unhappy)
And the car the insurance check paid for in full.. Tires are like 7 MONTHS old.
KendallP
Probably the office
Posted: 09/23/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Wow!
I feel like that rig has been in your signature the entire time you've been a member here, no?
When did this happen?
n0arp
FT
Posted: 09/23/21 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't take the chances - replace them. I've seen tires that look brand new but are aged out go. That $3100 will give you another ~7 years of service so consider it a $37/mo insurance policy.
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
ferndaleflyer
everywhere
Posted: 09/23/21 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my DP tires a month or so ago--2 fronts were 6 years old and 4 rears were 7 years old--with Hankooks. $2500 out the door, BUT, I sold my take offs to a contractor for his low boy for $700 right at the tire store so it ended up costing me $1800 out of pocket for peace of mind.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 09/23/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Buy proper truck tires and stay away from the RV ones they will last a lot more than 7 yrs. Just my thought's.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 2001 32.5' Okanogan 5th wheel, new to us after 5 yrs with the 28' Travel Aire. Lots of fun.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 09/23/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
If they had not sat for 2 years…had been used regularly I probably would have gone a couple more years on the rear, but not after sitting that long at that age. Went 10 years on the rear (7 on the fronts) on previous DP and I then put them on the back of my 10 wheel dump truck.
Just ordered 6 new tires for the rear…replaced the front 5 year old cracking Michelin’s when I bought the rig 3 years ago. Cracks on rear are getting big enough so replacing at 8 years.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
Desert Captain
Payson
Posted: 09/23/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
My rig is just a smallish {24'} Class C but the blowout of a 5+ year old Michelin the day after being inspected and aired up for the load by Discount Tire did $4,181 in damage blowing the wheel well right up through the coach. Had it been a front wheel it could have easily killed us. I'll never own a tire older than 5 years again.
My dear departed dad used to tell me "Son, any problem that can be solved by money is NOT a problem... If you have the money."
Just saying. Good luck.
[emoticon]
sehunter
Rancho Murieta, Ca.
Posted: 09/23/21 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Desert Captain,
Did your insurance cover a large percentage of that damage?
Stan
2008 Bounder
38P, W24, 8.1L, 3 Slides
2019 tow dolly hydraulic brakes
