RV.Net Open Roads Forum: Class C Motorhomes: Steering problems w/ 30 ft Winnebago
 > Steering problems w/ 30 ft Winnebago
Snomas
Sedona, AZ
Posted: 09/24/21 02:35am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a 2006 Winnebago aspect 29 h Motorhome and it wanders a little when driving at higher speeds. Can anyone give me advice on how to corrrect this problem?
BTW it has 57k miles on an E450 chassis..
* This post was edited 09/24/21 03:28am by Snomas *
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
phil-t
Ogdensburg, NY
Posted: 09/24/21 04:45am Link  |  Quote  |  Print  |  Notify Moderator
Take it to an alignment shop to have frontend parts checked out and get it an alignment.
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
ronfisherman
SE Michigan
Posted: 09/24/21 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Check tire pressure. Over inflated tires can cause wondering. Especially on the front.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
theoldwizard1
SE MI
Posted: 09/24/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Common problem. Take it to a shop that specialize in alignments. You need to have the caster adjusted to a range outside of the factory specs. This WILL NOT increase tire wear.
bobndot
Posted: 09/24/21 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Ask your shop about the need for a bushing set.
I had to add a ford bushing set in order to properly spec my E450.
2003-2017 Ford E450 Super Duty Alignment Caster / Camber Bushing Set, Ford E450 Super Duty Alignment Caster / Camber Bushing Set, DIY Solutions Alignment Caster / Camber Bushing Set SKU: 5024-07376532 Rear Wheel Drive; Front Steering 03-17 Ford Alignment Caster / Camber Bushing Set. Replacement Alignment Caster / Camber Bushing Set Parts. 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17
DrewE
Vermont
Posted: 09/24/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Do you have experience driving similar long-wheelbase vehicles previously?
While it's certainly possible that the alignment needs adjusting or some suspension parts are worn (both are quite common problems), it may also partly be you not being used to how the vehicle behaves. The natural tendency of many people at first is to overcorrect because it takes longer for the vehicle to respond to steering adjustments. Sometimes the solution is as simple as consciously looking further down the road and perhaps trying to make more gentle steering inputs to keep in the proper lane position.
Hank85713
Tucson, Az
Posted: 09/24/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Most of the above can be true, however there are things that you need to check first. Yes I own a 12 aspect. Check tire pressures, do not use the 75psi on sidewall or whatever is on door jamb. I run mine at 60-65 for fronts, 70 for rears. Depending on load what airbag pressures do you run? Again mine is 55-70 again depending on load. Have you weighed the rig mine comes in around 13500 we travel light. 1/3 tank water, empty black/grey tanks (all located over and back of rear axle).
When 1st got ours it did wander but I had to experiment with the above settings to get it to stabilize. I have new shocks to install and I got a new steer stabilizer but havent gotten around to putting on since we are not going to travel again this year due to the virus.
There was a road test back around 10-11 on the winnebago and these were also complained about, however I havent been able to find it since I read it years ago.
PM me if you have questions
Snomas
Sedona, AZ
Posted: 09/24/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
I drove a 31ft 1996 Safari Trek for 4 years (P30 chassis), a 40ft 2002 Newmar Duchstar for 15 years ( Spartan chassis) sold it in 2017 with 106K miles.
I will have the camber checked and form what I'm now reading , I will add a safe-T steer, Billstein shocks, and sway bars.
It has air bags but the previous owner rode it with only 25 PSI and I will increase to 40-50 PSI
I had the tires inflated to 55- 80PSI front to back. before I drove it home.
Thnaks for your input and I hope this all works out.
I love the fiberglass roof and interior quality of winnebago and think it's second to Coach House and Phoenix Cruise of that era.
Snomas
Sedona, AZ
Posted: 09/24/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I ran if with 80 rear and 55 front. What do you run in yours?
12th Man Fan
Flower Mound , Texas
Posted: 09/24/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Friend of mine had a Winney with the same issues. He bought an after market steering stabalizer and installed it himself. He was very pleased with the improvement.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
