RV.Net Open Roads Forum: Class C Motorhomes: Water leak under the Cab
 > Water leak under the Cab
mpisano
Boca Raton
Posted: 09/24/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Good morning, I have a Chateau 28z. And as I moved the RV on the storage parking lot where the grade changes. All of the sudden I see water coming down the long horizontal inverted half cane, under the bullnose. Is this a working as gutter? o I have bigger issues. I always check the roof and all the joints around the RV for any gaps. I did seal the clearance lights yesterday which I found out that the light seals are a joke. But they are located much higher. If it is the case, then the water will travel inside the bullnose into that bottom connector?.[image][image][image] Thank you in advance for any ideas or past experiences.
https://imgur.com/a6uukJT
IAMICHABOD
Sunny So Cal
Posted: 09/24/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Yes,I had the same problem on mine.Water leaked thru then came out just as yours did. Check inside under bunk and walls for water intrusion.
Former El Monte RV Rental
Buying A Rental Class C
mpisano
Boca Raton
Posted: 09/24/21 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
everything looks fine, unless it is something new. did you find the cause of the leak?Thank you
IAMICHABOD
Sunny So Cal
Posted: 09/25/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I sealed the clearance lights and applied Eternabond to the all the roof joints that are attached to the nosecone,problem solved.
